01-21-2013, 05:49 PM | #1 |
Head light conversion?
Hey folks,
Im new to the forum and to rebuilding trucks, so I'll explain my problem the best I can. I have an '82 Chevy C20 which comes with the dual headlight set up. All four come on when you click for the brights. Problem is when you just have the driving lights on (no brights) its very dim for my liking. I found some Hella lights that would love to put in the truck but the are hi/low fixtures. I don't necessarily want to get rid of the 4 head lights...cuz I like that look...but is it possible to put hi/low fixtures in, while keeping my 4 lights? or do I need to stick with the set up as is? If so...are there some brighter lights/fixtures you guys can recommend to replace these for better light output? Thanks for your time! |
01-22-2013, 09:12 PM | #2 |
Java Mechanic
Re: Head light conversion?
You can wire up anything you want if you do it right. You can also look up i the stickies above for a nice break down on doing an HID conversion.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
01-23-2013, 12:20 AM | #3 |
I have upgraded those #4652 small rectangular sealed beams to Hella or Bosh in the past. The ones using the replaceable 9003 / H4 bulbs for the hi/low (upper) bulb and the H1 for the high (lower) beam.
The 4652 sealed beam bulbs (hi/low) have unique plug wiring and you have to use an adapter. My Hella H4 kit came with them. (See the picture.) The high beam H1 kit is a straight change-over. I would suggest also installing a HD headlight wiring harness at the same time you put the Hella kits in. It helps give more voltage to the bulbs and more loght. |
01-24-2013, 11:45 AM | #4 |
Hella's will make a huge difference, along with a relay harness to bypass the old wiring, and higher wattage bulbs.
Here's a couple pics of the low beam pattern with Hella H4's, 10g harness with 50 amp relays, and Hella 80/100 watt bulbs.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-24-2013, 12:39 PM | #5 |
78K & 79C Jimmys
I put my lows on the bottom ,highs on the top
helped a bit,but those should be even better
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
