Old 02-07-2023, 05:35 AM   #1
AllGoNoShow
Differences in brake booster brackets/linkages…
I have a 68 which previous owner converted to front power disc brakes. Not sure who the manufacturer is but it has what appears to be a 8” dual diaphragm booster which has the brackets and swivel type linkage outside of the firewall as seen below. This puts the MC pretty far out from the firewall and the whole thing leans forward and doesn’t sit close to level for some reason (see below).
I’ve also seen some people put the booster closer to the firewall with Captain Fab’s brackets which seemingly puts the booster lined up with the hole in the firewall so no swivel linkage is needed.
What are the pros/cons of each? The only reason I see for the larger bracket with swivel linkage is that it moves the booster up so there is more room? Trying to evaluate my brakes and understand all the differences as I’m looking to replace the MC and proportioning valve. Thanks!
AllGoNoShow is offline   Reply With Quote
Old 02-07-2023, 07:12 AM   #2
RustyPile
RustyPile's Avatar
Re: Differences in brake booster brackets/linkages…
You appear to have the very common booster/MC conversion setup sold by Summit.. The "swivel linkage" as you call it if actually reduces the pedal travel needed to move the MC piston. Here is a link to the setup sold by Summit.. BTW, I've had this unit in my truck for ~ 4 years and it has been trouble free..
https://www.summitracing.com/parts/sum-760197
RustyPile is offline   Reply With Quote
Old 02-07-2023, 08:29 AM   #3
A1971Blazer
A1971Blazer's Avatar
I bought this one from a fellow board member and installed it on my K/5 Blazer.
https://67-72chevytrucks.com/vboard/...hlight=booster
I'm not sure why they all tilt downward but I shimmed under the bottom bolts and leveled it.
The difference in braking is like day and night compared to the old factory one.
It easily locks all 4 wheels.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-07-2023, 08:54 PM   #4
kev2809
low n' slo
kev2809's Avatar
i ordered an 8" one for a c10 off ebay and it looks exactly like yours, and mine sits exactly the same. i dont like it, and also i feel like because its leaning, brake fluid comes out the front when the brakes are applied. i dont know if maybe the lid isnt exactly squeezed tight, because it does seem like it could be more snug. the seller said i could try shimming the bottom of the bracket to the firewall. but it does stick out a lot more than the one that i had on the truck before
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-07-2023, 11:17 PM   #5
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Well the master cylinder lid should be air tight. So if you are loosing fluid from the lid then it's not sealing properly.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 02-08-2023, 07:23 AM   #6
kev2809
low n' slo
kev2809's Avatar
ya I think I have a lid issue as well then.
does the push rod need adjusting again if the bottom bracket is shimmed?
OP, if your brake lines reach fine I would leave it alone. I don't know why they sit so far out though, and angle down. but it seems most aftermarket ones do
-_--_--_ _________
Old 02-08-2023, 08:57 AM   #7
A1971Blazer
The push rod might need a slight adjustment if you shim the bottom of the bracket after you have already installed and adjusted it.
I did a full install, so I attached the rod to the pedal after I mounted the booster.
It works flawlessly.
1967 C10 Step side
1968 C10 Step side
Old 02-08-2023, 11:47 AM   #8
69cam
Sorry to hijack this thread. Thank you A1971 blazer for posting a pick of this setup. I have been thinking about purchasing one. Is yours the cast iron version and can you confirm that it does not have CPP cast into it? Thanks for any help.
69cam is offline   Reply With Quote
Old 02-08-2023, 02:26 PM   #9
68 C10 Driver
AllGoNoShow, mine is very similar to yours but my booster is the larger size. I do not think mine tilts quite as much, but here is how it looks. I am still into my build, so I do not have fluid in it yet.
68 C10 Driver is offline   Reply With Quote
Old 02-08-2023, 06:02 PM   #10
68 C10 Driver
Here is a good side view, I guess the tilt is a bit more than I thought, but it isn't crazy...
Old 02-09-2023, 08:01 AM   #11
A1971Blazer
the master cylinder is cast iron, I cleaned it with laquer thinner and painted it. I hate seeing a rusty master cylinder.....
and no, there is no lettering or anything on the master cylinder, it came with the proportioning valve and the lines to connect it to the MC...
1967 C10 Step side
1968 C10 Step side
Old 02-09-2023, 11:26 AM   #12
69cam
Thank you for the reply. That's good to know. I plan to order one soon. Thanks again.
Old 02-10-2023, 05:30 AM   #13
AllGoNoShow
So besides the first reply mentioning that this type of linkage allows for less pedal travel to move the MC, is there any other advantage to this bracket then the ones that keeps the booster closer to the firewall with the connection/linkage being entirely inside the cab? It seems unnecessarily complicated if that is the only reason.
Old 02-10-2023, 07:43 AM   #14
ghackett1
68 C10 Longbed
ghackett1's Avatar
I like the look of that set up, where did you get it?
ghackett1 is offline   Reply With Quote
