Old 08-22-2010, 11:01 PM   #26
sick454
sick454's Avatar
Re: 5.3 SWAP Wiring Problem
Yes they are both connected, I have been Coresponding with Jesse at W4M, he said to check the harness, make sure all the pink wires have 12Vdc, funny... I sent it to them to get it fixed in the first place, didn't think I would have to double check there work! If that was the case I would have done it myself.
I found Three grounds, the two in the back pf the engine, that you pointed out, and one on the front, behind the Power Steering pump. Then My Chasis, Engine, Body and Battery Ground straps.
sick454 is offline   Reply With Quote
Old 08-22-2010, 11:13 PM   #27
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Would it possibly need a crank relearn procedure done for some reason?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-22-2010, 11:23 PM   #28
sick454
sick454's Avatar
It might, How do you do that? I don't have a check engine light to view any codes. Any idea's how to rig one up?
Old 08-22-2010, 11:34 PM   #29
eagleuh1
eagleuh1's Avatar
What fuse box are you using for your harness. Verify the fuse is good/ there. Verify connectors at the fuel rail are connected good. This is the connector on each side of engine that connects coil harnesses to engine harness.
eagleuh1 is offline   Reply With Quote
Old 08-22-2010, 11:39 PM   #30
sick454
sick454's Avatar
I'm using the original 72 fuse block with an inline 15 amp fuse to the harness then a 10 amp fuse to the ECM/PCM.
Old 08-23-2010, 12:14 AM   #31
68GMCCustom
some reading on it:
http://www.trifectaperformance.com/t...ankrelearn.htm
Kurt -
Old 08-23-2010, 09:51 AM   #32
sick454
sick454's Avatar
Originally Posted by 68GMCCustom View Post
So, based on this I'm screwed. It is not the original PCM for my Engine, But it is a PCM for the 2007 and 5.3ltr engine. This tells me I have to buy a tuner that will initiate the Relearn program or take it to a Stealership to get them to do it. However, I can't do that until I get it started. Also, according to this it will still run but not run very well? It will just throw the code.
Old 08-23-2010, 10:40 AM   #33
Clyde65
Clyde65's Avatar
I dont know if this will help you but my swap had the same issue, however when I found one of the W4Me supplied harness power needs was a constant 12v through the key on and start process was lacking, I put one from the fuse box and it started and ran. I used the W4Me harness and sort of stock truck harness along with the fuel pump and fan relays. Hope it helps.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-23-2010, 01:08 PM   #34
eagleuh1
eagleuh1's Avatar
What fuse box are you using in the engine harness. Theres fuses for the injectors and coils and other various systems in the engine harness. It requires some kind of fuse box such as the under hood fuse box from the donor vehicle or an after market one from Current performance. Check the fuses in this fuse box to verify good, or there/installed.
Old 08-23-2010, 01:12 PM   #35
68GMCCustom
you can send your PCM and VIN to a good tuner...and they will put the factory loads for your VIN into the PCM...once thats done, they tune it for your individual needs (fuel octane, elevation, reduction of torque management, etc.) before returning it to you. With this done a crank relearn shouldn't be necessary.
ALL of this is one of the reasons I am putting a carb on my LSx.
Kurt -
Old 08-23-2010, 03:04 PM   #36
sick454
sick454's Avatar
OK here is what happened, Went and got a Scanner and the only codes it's giving me are the HO2S Heater codes. And that should not keep it from running. (P0030, P0036, P0050, P0056) I asked WFM to remove the two they recommended to remove (the back, I think), and still nothing. Jesse swears there is nothing wrong with it. I am severly frustrated! Then he wants me to go buy 4 O2 sensors and leave them hanging to see if it will start then??? They are a little expensive for me to just experiment with them.
Old 08-23-2010, 03:58 PM   #37
sick454
sick454's Avatar
Alright, I went out to double check, I only have two O/2 sensor plugs (W4M remove the two rear ones) but the Scanner is giving me four 0/2 codes. unplugged the MAF sensor and still nothing. Anyone with ideas? Thay haven't been discussed thus far?
Old 08-23-2010, 04:36 PM   #38
sick454
sick454's Avatar
W4m said all i need is the 15 amp fuses on the pigtails they intalled and a 10 amp fuse on the white constant power to the PCM. There are no Fuses to the coils, or injectors other than these.
Old 08-23-2010, 05:59 PM   #39
eagleuh1
eagleuh1's Avatar
OK, he's got inline fuses installed. No bulky fusebox to look at then. Check to verify theres actually a fuse installed in the holder, and that it still is good. Have you checked to verify you have power on the circuits that energize when the ignition key is on and also in the crank positon. It will go through a relay to energize these circuits. With an aftermarket harness I don't know where'd he'd put this relay, but verify it's working. It sounds like it is if the injectors are cycling, but he may have them on seperate relays.
Old 08-23-2010, 06:00 PM   #40
eagleuh1
eagleuh1's Avatar
If you can get some noid lights from somebody, you can check to make sure the injectors are all cycling.
Old 08-23-2010, 06:13 PM   #41
Clyde65
Clyde65's Avatar
Like I said and Eagle said, one of those wires that W4Me supplied needs key on 12v even when cranking so it will run, I will need to look when I get home to see which wire it was on mine. I would call W4Me and ask which one needs that kind of power to it.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-23-2010, 10:02 PM   #42
sick454
sick454's Avatar
Unhappy Re: 5.3 SWAP Wiring Problem
OK, First, I WAS WRONG. There that's out of the way. It started. Come to find out I had the fuel pump wired backwards. I knew it would be something stupid and easy. and it was. Each terminal is different sized. Ones large and one is small. Naturally I assumed the Large on was the positive. I was wrong (dang said that twice) the little one is positive. Once I swapped it. It fired right up.
Now to hook up oil pressure and water temp gauges and then a trip to the muffler shop! IT's LOUD!!!
Oh and yes it was labeled which was positive and negative, however at 10 pm on a saturday night, under a truck, in the dark, it's hard to remember to look and verify it.
I wanted to Thank everyone who chimed in and offered help. they were all great idea's. Now on to the next step!
Old 08-24-2010, 09:45 AM   #43
Clyde65
Clyde65's Avatar
I did the same thing......I completely understand how that could be missed.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-24-2010, 10:02 AM   #44
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I'll have this moved this to the LS swap area for future reference.
BTW, when I tried to start mine for the time, I also had fuel but no spark. Turns out the "key on" wire I had chosen to trigger my ignition coil relay had 12v when the key was in the "run" position, but lost power when in the "start" position. Changed the trigger wire to one that had power in both "run" and "start" and it fired right up.
Glad it finally started for ya!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-24-2010, 01:00 PM   #45
eagleuh1
eagleuh1's Avatar
Awesome, glad you got it figured out and was something so simple and cheap to fix. How bout some pictures now.
Old 08-24-2010, 01:23 PM   #46
faribran
its good that you guys share this kinda info.... will be helpful to others down the road...
this makes the challenges more fun.
faribran is offline   Reply With Quote
Old 08-24-2010, 06:43 PM   #47
Ackattack
Ackattack's Avatar
I had the exact same thing when I was doing my TPI swap, but occasionally, the engine had enough inertial to spin enough, that when I let off the "start" back to the "run" it would fire up.....that had me stumped for a week!
Glad you got it fired up
Ackattack is offline   Reply With Quote
Old 08-24-2010, 10:11 PM   #48
tk-mpl
tk-mpl's Avatar
I feel your pain, it took me 3 weeks of more then just sundays to get mine going. I rewired and reprogrammed with EFI Live myself. Went to start it and had no injector pulse and no spark. I rechecked every pin on the ECM and traced a lot of the wiring... LONG story short I reflashed it with a different vin and it started right up........ But man, all the hate was gone when the sound of open headers scares the crap out of you.......
Trevor
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
2007, 5.3, diagram, harness, wiring
