05-15-2023, 08:22 PM | #1 |
Lug nut Size ?
A while back I picked up a set of rally wheels off a 4X4. I then purchased caps and conversion lug nuts. After looking at time I believe I have the wrong size lug nuts. I purchased the lug nuts with the 7/8 Hex. These don't appear to fit into my wheels properly...
Should these wheels use the 3/4 Hex or the 7/8 Hex ? Last edited by Bunky; 05-17-2023 at 06:48 AM. |
05-17-2023, 12:08 PM | #2 |
67-72 parts collector,…
Re: Lug nut Size ?
That’s the same thing I have used in the past.
The hex size on the conversion lug nut is 7/8 or 22mm. I had no issue with the taper of the lug nut.
05-17-2023, 12:14 PM | #3 |
Re: Lug nut Size ?
Both lug nuts should have a 60 degree taper.
05-17-2023, 09:54 PM | #4 |
Re: Lug nut Size ?
What is a conversion lug nut?
05-18-2023, 05:04 AM | #5 |
Re: Lug nut Size ?
Tags |
4x4, rally wheels |
