Old 05-26-2021, 04:40 PM   #126
siggyfreud
siggyfreud's Avatar
Re: Project "Ghost" - 1972 C10 Pro-touring
Refined further based on more measurements:
siggyfreud is offline   Reply With Quote
Old 05-26-2021, 06:20 PM   #127
siggyfreud
siggyfreud's Avatar
And in case I don't want to be subtle:
Old 05-27-2021, 06:59 PM   #128
siggyfreud
siggyfreud's Avatar
Opening up the slots on the back still wasn't enough. But after doing the test print and seeing how well the supports help up the pocket I decided I could save a little material opening up the whole back more. I did have to give it more depth on the back though to clear the headlight and washer tabs, so it might be a net add in material overall. So we'll try this next!
Old 05-27-2021, 07:35 PM   #129
Kronald_70GMC
Kronald_70GMC's Avatar
Man I wish I had one of those printers! And the knowledge to run it I could make some pretty cool parts too.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 05-29-2021, 03:55 PM   #130
siggyfreud
siggyfreud's Avatar
It really is fun, though can be frustrating at times for sure!
I think I'm honing in on the final design for this cluster though. I opened up the back more, as clearance is still an issue. I went ahead and went with a flat design for the back to reduce weight. On the one hand, it saves in some material costs for printing, on the other, it means more cutting time on a CNC . . .
Old 05-29-2021, 09:21 PM   #131
TA_C10
TA_C10's Avatar
Re: Project "Ghost of Poseidon" - 1972 C10 Pro-touring
Looks great man, can't wait to see the final product!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 05-29-2021, 10:05 PM   #132
Kronald_70GMC
Red face Re: Project "Ghost of Poseidon" - 1972 C10 Pro-touring
Ok question for you, how did you change your thread title?
Kyle
IG: kyle_ronald
Old 05-29-2021, 10:22 PM   #133
siggyfreud
siggyfreud's Avatar
I PM'ed a mod (leddzepp) and they were able to change it for me.
Old 05-29-2021, 10:23 PM   #134
siggyfreud
siggyfreud's Avatar
Gauges are on order, and printing what I hope is the final test of the back pocket design, then I'll print and assemble the two pieces from matte black plastic. If I love it then I might look at getting it milled. I wish I had a CNC, but have no room for one right now (plus they're spendy as hell).
Old 05-30-2021, 01:19 AM   #135
Kronald_70GMC
Thanks for the info. I was able to finally get mine changed as well.
Kyle
IG: kyle_ronald
Old 05-30-2021, 02:39 AM   #136
siggyfreud
siggyfreud's Avatar
Not a problem .
Had some downtime while a test print is going, so I designed a plate to go over where the previous fuse box was. Going to see if I can use that square cutout from the old firewall plug to run new power bulkheads for rewiring.
This plate will cover the square hole, and give 1 bulkhead for a 4 or 6 awg wire to feed power to the fuse block, and then a bulkhead to provide power to various chassis components (headlights, turn signals, horn, etc.).
Eventually, when I do an LT motor I'll likely have 1 additional plug for all the engine power/sensors/etc.
These are standard Deutsch connectors. The multi-wire bulkhead it a step down from their pro-racing series, and since this isn't like an F1 car I think it'll suffice. Eventually, I might polish the actual connector, as it's aluminum, but unpolished.
Old 06-02-2021, 10:45 AM   #137
siggyfreud
siggyfreud's Avatar
First half printed!
Removeable rear support grid:
Front side:
Next step is to print the second half and then bond them together.
Old 06-02-2021, 10:59 AM   #138
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice, looks good.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-02-2021, 11:27 AM   #139
SCOTI
SCOTI's Avatar
That is just too cool.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-28-2023, 11:44 PM   #140
siggyfreud
siggyfreud's Avatar
Well it's been a long time, and honestly I haven't worked directly on the truck much. But I have been hard at work building my company, getting space, renovations (still ongoing, etc.)
I have also taken my prototyping a step further and invested in a CNC, and a few days ago was able to make my first gauge prototype. Made a few errors, but the next one will be even better. I'm having this one powder-coated black and will mill back off a few accents. Once I have the base template down I'll be able to customize these to any theme or build, gauge config, etc. but that's down the road. For now, a few shots of what I built for Poseidon.
Old 06-28-2023, 11:45 PM   #141
siggyfreud
siggyfreud's Avatar
And a shot of the rear reliefs before the front-side was cut:
Old 06-29-2023, 09:17 AM   #142
SCOTI
SCOTI's Avatar
Pretty!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-29-2023, 11:46 AM   #143
siggyfreud
siggyfreud's Avatar
Originally Posted by SCOTI View Post
Pretty!
Thank you
Old 07-02-2023, 02:36 PM   #144
siggyfreud
siggyfreud's Avatar
Back from powdercoat. I need to open up the top holes more as the powder made them too tight for the gauges to nest inside the holes as they should.
Old 07-02-2023, 03:06 PM   #145
Pingar
Love the new gauge cluster.
Pingar is offline   Reply With Quote
Old 07-03-2023, 12:38 AM   #146
siggyfreud
siggyfreud's Avatar
Tossed it back in the mill to cut off the powdercoat around the top contour, and gave it a roughened edge for some texture.
Also trying out Photoshops AI-generated background so it's not just propped up on my dirty workbench .
Old 07-04-2023, 10:56 AM   #147
cornerstone
cornerstone's Avatar
Nice work! That's gonna look great in the truck.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 12-05-2023, 03:44 PM   #148
siggyfreud
siggyfreud's Avatar
Been awhile since some updates, but wanted to post a bit more work on another interior part I'm developing. I'm likely leaving my job early next year and going full time into my own business, and preparing for that in my free time. I won't post anything more here about it for now so as not to give the impression I'm advertising.
In any case, I picked up a new tool recently that will allow me to build parts faster. I'm not using a 3D scanner to help pick up dimensions. When I did the dash piece I used calipers to find all the bolt/hole locations, and it took several iterations of 3d printing, measuring, etc to get it right. I hope to reduce that cycle quite a bit with a scanner.
So I took off the glove box door and did a scan of it:
I was then able to import that data in my CAD, and start building a model from it.
With that, I was pretty quickly able to build a model of a prototype that I can then further customize/beutify for specific builds in the future.
All of this was done in about 7-8 hours of work time. Another day of work or so and I could likely have a prototype milled, or send 3D print it in a few days for a test fit out of cheap material.
All very cool stuff!
Old 12-05-2023, 04:44 PM   #149
SCOTI
SCOTI's Avatar
Very cool stuff indeed!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-06-2023, 01:22 AM   #150
siggyfreud
siggyfreud's Avatar
Another variation:
