03-01-2012, 10:23 PM | #1 |
I am a Referee of life.
Headlight relay ???
I'm planning on doing the hedlight relay upgrade.Here are the questions I have.
1.Are the connectors in the Bulkhead connector on the firewall all the same?I'm wanting to run the Green and Tan wires new all the way from the firewall so I don't have any splices. 1a.What size wire?I'm thinking 14 ga or above will be plenty. 2.Is there any advantage to running a relay on the Park lights/Turn signals?I'm thinking the draw is small enough to not make much difference. 3.Is a #10 wire guage overkill to feed the power to the relays? 4.Should I upgrade the power wire from the battery to the Main power block on the inner fender? 5.I read a couple of threads but didn't see what the fuse shuld be rated at.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-02-2012, 05:44 PM | #2 | |
Msgt USAF Ret
Re: Headlight relay ???
Here is one for the GMC's
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 03-02-2012 at 06:08 PM. |
03-02-2012, 05:46 PM | #3 |
#1 yes
#1a 16-18 gauge is all you need. #2 No need #3 12 gauge is big enough. #4 good idea #5 Use a fuseable link. Do not put a fuse in the headlights. |
03-02-2012, 09:42 PM | #4 |
Tanks Wrenchbender,I pretty much thought I was close to what was right,just wanted confirmation.I think you're right about the 16-18 a relay coil wont pull much.
03-02-2012, 11:53 PM | #5 |
Why a fuse able link and not a fuse?
Proud to be IBEW Local 2150 |
03-03-2012, 01:59 AM | #6 |
*** That's interesting ***
Safety (and liability if you are GM). You don't want a fuse heating up and blowing randomly on a dark country road. A fuse can fail just with age if it is pushed anywhere near their limit for extended periods of time. Due to the nature of the filament, they can also draw much more current at startup versus steady burning. And this can also blow fuses, especially when blinking your lights or switching from high to low beams.
The safest thing to use is a self-resetting (quick reset) circuit breaker. That is what the factory preferred for many years and typically included one inside the headlight switch itself. Instead of a fusible link, if you really want to use a fuse, I guess it would be OK to overrate the fuse by 50-100% to help make it more reliable (since a fusible link will be ridiculously overrated as well). But if it were me, I'd use a self resetting breaker.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 03-03-2012 at 02:07 AM. |
03-03-2012, 02:46 PM | #7 |
Ya ok. I'm gonna be doing the upgrade to and was thinking a breaker or fuse, and like you said, fuse it at 50 to 100%. There are pros and cons to both. But I really dont like the idea of a fusable Link under the hood. I just wanted your opinion and any other reasons. Thanks storm
03-05-2012, 11:51 AM | #8 |
Msgt USAF Ret
Did my post no. 2 not show up?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-07-2012, 08:48 PM | #9 |
It has now VV.Thanks.
