20' Daredevil (Ret)
![]() Join Date: May 2003
When installing new brake hoses, should you use anything -- antiseize, loctite, something else -- on the threads? Thanks..
Moderator
![]() Join Date: May 2007
Re: Another dumb brake Q
i never have used thread lock. i dont think the factory did (i could be wrong).....but i have yet to encounter an original line that was even remotely close to being loose, LOL!
i dont know that i would use anti sieze either, as i would not plan on removing them again. sorry im not much help! Posted via Mobile Device
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
~Rest In Peace~
dont use anything
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
They do go together dry. The only stupid or dumb questions are the ones that are left unasked. I mean we all started to learn somewhere and how else do you learn ecept asking? do it wrong on something like brakes/suspension and it could be ugly. Do it wrong to a tune up and your just in the driveway with a ill running truck. So I don't think that anyone asks a stipid or dumb question if they are seeking an answer
![]() Join Date: May 2012
stocker: their is no dumb brake question, that is the most important part of any vehicle...
++ Don't use anything on the lines.
I use a dab of anti-seize on the bleeder screw.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
20' Daredevil (Ret)
Thanks, all! Good tip on the bleeders too. I am just now installing the driver's side front hose..... pass. side looks to be a bit tighter access, I'm doing the easy side first so I'll know exactly how things fit together.
Edit: One down ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 05-28-2012 at 12:29 PM. |
![]() Join Date: Apr 2007
The manufacturer (and most mechanics) never use anti-seize anywhere because it's extra work,messy,and they don't care about your "next time". I use anti-seize on any chassis bolt I want to come off and still use again. Brake lines usually seize at the line and fitting,so I slide the fitting back and get it worked in there good,too.
