03-28-2022, 04:58 PM | #1 |
Correct fuse
If I'm reading this right, the terminals represented by #3 take a 15A fuse for heat only, but for A/C it takes a 25A fuse. Correct or?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-28-2022, 05:09 PM | #2 |
Re: Correct fuse
This subject has come up several times in the past.. This is a link to the most recent discussion
. http://67-72chevytrucks.com/vboard/s...d.php?t=831762 The "heater only" fan motor is less powerful and requires only a 15 amp fuse.. If the vehicle is equipped with AC, the correct fuse is 25 amp. |
03-28-2022, 05:36 PM | #3 | |
Re: Correct fuse
