Old 06-14-2002, 04:14 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Whats the best way to remove old bondo?
I was waxing my truck the other day, when i saw a little crack in the paint above the rear wheelwell. I picked at it with a key, and discovered about a 1'x2' patch of 1/4" deep bondo on my rear quarter panel, for no apparent reason. I can't seem to find any dent beneath it, but i haven't removed it all yet. I started with a sander, but it will take a long time like that, i am using 100 grit sandpaper. Is there any faster way to remove to old bondo, like a chemical or someting like that?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-14-2002, 04:26 PM   #2
HuggerCST
HuggerCST's Avatar
36 grit paper on a hand grinder, or a cupped wire brush on a hand grinder both have worked well for me, but you may want to were a dust mask. I bet you're going to find a dent under there, though.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 06-14-2002, 04:26 PM   #3
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
You could use a paint stripping tool. it's like a bunch of metal rods that spin and tear off paint, it worked pretty well when i did mine, it still take a while though.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 06-14-2002, 04:30 PM   #4
Travis
Travis's Avatar
Smile
I used a wire brush on a drill on mine.
Travis is offline   Reply With Quote
Old 06-14-2002, 04:32 PM   #5
lukecp
lukecp's Avatar
I might try some 50 grit paper, it is the roughest i can find. After about 5 minutes of sanding, i went out and bought some dust masks, lol. It didn't feel too good to inhale bondo dust....
Old 06-14-2002, 04:36 PM   #6
Travis
Travis's Avatar
Smile
That is some dusty stuff.
Old 06-14-2002, 04:57 PM   #7
jku72
A sander grinder, if you have one, takes away bondo in about 2 seconds, in a blinding cloud of dust. I bet there is a slight body defect that caused it to be there though, and some dents are not detectable to an untrained hand. Forget a visual, only feeling them works 100%. A long stoke of the hand can detect a lot, or, on a smooth finish, a light coat of oil(careful of the type) and a strategically placed light can show up slight imperfections as well.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 06-14-2002, 05:35 PM   #8
jay-dawg
chevelito
jay-dawg's Avatar
stroking and light oil????
just messing with you man....I have the same problem here and want to see what other ideas come up.
thanks,
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 06-14-2002, 08:52 PM   #9
lukecp
lukecp's Avatar
Well, i got most of the bondo removed, but it is getting dark now. I used a coarse wire brush on my electric drill to take off most of it, and then got the rest of it off with my electric sander and 100 grit paper. It appears that the truck was T-boned in the rear quarter panel, and they pulled out the dent. There are about 10-15 small dings, and several depressions, none more than 3/8" deep. They got a little happy with the bondo, they put it on some places about 1/8" thick where there is no dent at all. What would be the best way for me to fix this? Should i just bondo it again, but take my time on it? Can i use fiberglass to fix this? My quarter panel isn't rusty at all, but i have seen new ones for sale in several magazines.
Old 06-14-2002, 11:11 PM   #10
PushinPebbles
My dad's 68
PushinPebbles's Avatar
I think the lowest grit they make is 36.................which looks like rocks glued to paper...........Why would you use Glass' if there is no rust???...............Fill it ,sand it,fell it, finish fill it, primer it, and ride the hell out of it.....................I skiped the paint process.......
sorta gives u a idea of my truck...........all colors..........
hehehe.......................Jack
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 06-15-2002, 12:40 AM   #11
chevyman 68 C/10
chevyman 68 C/10's Avatar
The sander grinder is the way to go. You can go as low as 24 grit but you need to keep it moving and not stay in one spot if you go that course.The safest is 36 grit.
You will need to use something like this to rough up the metal before applying more body filler to get good adheasion to the damaged area.
Chevyman 68 C/10
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 06-15-2002, 08:43 AM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Be careful with the heavy grit sanding disc's.They can build heat and cause warping.The lighter ones will also but generally you are doing lighter work with the lighter grits and not pressing as hard causing friction to build heat.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-15-2002, 09:26 AM   #13
MOTHERTRUCKERS
If the dents are where you can behind them then a little hammer and dolly work might be in order before the bondo, some minor dents can be worked out by shrinking the metal that way, you can get cheap hammer and dolly sets at most auto stores,eastwood, jc whitney etc. or a quality shrinking hammer for about 75.00. I make my dollies out of lead melted to conform to a particular good panel on these trucks then use it to fix the dented panel. But thats all we do all day is fix dented,rusted trucks so it's worth the time to make custom dollies. Be sure to use a good quality bondo that will not shrink like RAGE, some bondo will shrink when fully cured 3-10 days even after painting.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 06-15-2002, 11:13 AM   #14
sub4rvr
sub4rvr's Avatar
I think it's funny that you started out waxing your truck, and ended up taking a sander to it. Sounds like a typical day for me. try to get one thing done, and end up doing five.
72 C10 Suburban
90 S10
57 F100 (2)
67 Mustang (2)
69 Torino GT
00 Mustang GT Conv.
sub4rvr is offline   Reply With Quote
