05-20-2021, 04:46 PM | #1 |
Transmission "Bump" at stop
Fellas,
After I put in a new crate 350 about 3K miles ago, I've noticed something little odd with the transmission - which is a TH350 auto with the standard 3 on the tree for a 64. It shifts fine and smooth, kick-down is perfect - but sometimes when I get to a stoplight, I feel a very slight bump - like it's "resetting" into 1st gear - after it's already dropped to 1st. Performance is great, fluid level is good - it's just a new thang. I'm curious if this is a sign of bad things to come, torque converter related (?), or the classic "Nothing to see here...". Any thoughts/comments appreciated - as always.
64 C10 Custom 70 C10 Stepside w/67 Front End Clip 1970 Buick Ragtop 2003 Anniversary Road King Classic |
05-20-2021, 05:08 PM | #2 |
Moderator
Re: Transmission "Bump" at stop
Couple of things to check:
Vacuum modulator hoses are in good condition and vacuum port in manifold is not clogged... Engine idle speed a tad too high Trans fluid a little low...how long since trans filter and fluid was changed? I doubt the convertor is an issue....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-20-2021, 05:54 PM | #3 |
Driveline/driveshaft bind up like that's has been so common in modern trucks?
05-20-2021, 10:06 PM | #4 |
Three on the tree is a 3 speed manual shift on the steering column. It is not a automatic transmission
Pulatoy |
05-20-2021, 10:58 PM | #5 | |||
"I ain't nobody, dork."
Check to see if the torque converter bolts are tight at the flex plate. Gary
05-21-2021, 09:10 AM | #6 |
What carb?
Maybe fuel level isn’t ‘great’ once in awhile. Could be A very slight bit of sloshed fuel. Gives a little surge. What distributor? Weights could be hanging up. And is vac advance hooked to ported or manifold vacuum port? Last edited by geezer#99; 05-21-2021 at 10:06 AM. |
05-21-2021, 10:29 AM | #7 |
Yeah, automatic. Don't know why I keep thinking that...sounds pretty cool though, right?
05-21-2021, 01:20 PM | #8 |
Might double check the motor and trans mounts for tightness. Several hundred pounds of engine/trans settling back into place can often be felt.
Also check the bolts holding the engine/trans together plus the bolts on the flex plate. Something loose/worn in the rear end/spring shackles? |
05-21-2021, 06:01 PM | #9 |
Like has been suggested I would remove the driveshafts and check out the U joints.
05-23-2021, 10:04 AM | #10 |
