05-19-2021, 01:54 PM | #1 |
Big Block help
I'm looking at a 454 engine today. 12550313 casting number. 4 bolt main engine WITH the mechanical fuel pump boss machined into it and it has a pump on it now. 6 bolt aluminum timing cover and 1 piece rear main seal. If I did my investigating correctly, this should be a Gen VI...yes? Any input would be greatly appreciated....Patch
Patch |
05-19-2021, 02:02 PM | #2 |
Re: Big Block help
05-19-2021, 02:05 PM | #3 |
Re: Big Block help
With the 6 bolt cover I believe that designates it a 6...but that's what I'm trying to verify. I've also read that Gen V's did not have the mech fuel pump boss machined or even present....so much too learn...lol. Thanks...
Patch |
05-19-2021, 06:51 PM | #4 |
Re: Big Block help
Could be a crate motor...
05-20-2021, 04:29 PM | #5 |
Moderator
Re: Big Block help
Details for 12550313
Manufacturer Chevrolet Category Engine Blocks Type Big Block V8 Date 1991+ Notes 454, 4 bolt, Generation V crate motor, Generation VI 4.25 bare block, fuel pump boss More info if you are interested... No Gen 5 has a fuel pump boss. Gen 6 crate and service blocks do. Gen 5 timing covers LOOK like MK IV but are different at the pan seal. Gen 6 timing covers only have 6 bolts. Gen 5 and MK IV have 10, The lifter bores on the Gen 6 are approx. .300 taller than MKs and Gen 5. Be very careful if you are considering a flat tappet mechanical cam for a Gen VI ...lots of areas where it can go very wrong...hyd roller is the way to go IMHO
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox Last edited by AussieinNC; 05-20-2021 at 04:39 PM. |
05-23-2021, 06:22 PM | #6 |
Re: Big Block help
Got it apart yesterday. Definitely a Gen VI replacement block. Still has crosshatch in the cylinders. Could be fun to rebuild it as a roller! Interesting that the guide plates are marked Mark V. The stamp on the back of the block I don't know what it means either.
Patch |
