05-20-2021, 04:46 PM | #1 |
Transmission "Bump" at stop
Fellas,
After I put in a new crate 350 about 3K miles ago, I've noticed something little odd with the transmission - which is a TH350 auto with the standard 3 on the tree for a 64. It shifts fine and smooth, kick-down is perfect - but sometimes when I get to a stoplight, I feel a very slight bump - like it's "resetting" into 1st gear - after it's already dropped to 1st. Performance is great, fluid level is good - it's just a new thang. I'm curious if this is a sign of bad things to come, torque converter related (?), or the classic "Nothing to see here...". Any thoughts/comments appreciated - as always.
64 C10 Custom 70 C10 Stepside w/67 Front End Clip 1970 Buick Ragtop 2003 Anniversary Road King Classic |
05-20-2021, 05:08 PM | #2 |
Moderator
Re: Transmission "Bump" at stop
Couple of things to check:
Vacuum modulator hoses are in good condition and vacuum port in manifold is not clogged... Engine idle speed a tad too high Trans fluid a little low...how long since trans filter and fluid was changed? I doubt the convertor is an issue....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-20-2021, 05:54 PM | #3 |
Driveline/driveshaft bind up like that's has been so common in modern trucks?
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
05-20-2021, 10:06 PM | #4 |
Three on the tree is a 3 speed manual shift on the steering column. It is not a automatic transmission
Pulatoy |
05-20-2021, 10:58 PM | #5 | |||
"I ain't nobody, dork."
Check to see if the torque converter bolts are tight at the flex plate. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-21-2021, 09:10 AM | #6 |
What carb?
Maybe fuel level isn’t ‘great’ once in awhile. Could be A very slight bit of sloshed fuel. Gives a little surge. What distributor? Weights could be hanging up. And is vac advance hooked to ported or manifold vacuum port? Last edited by geezer#99; 05-21-2021 at 10:06 AM. |
05-21-2021, 10:29 AM | #7 |
Yeah, automatic. Don't know why I keep thinking that...sounds pretty cool though, right?
05-21-2021, 01:20 PM | #8 |
Might double check the motor and trans mounts for tightness. Several hundred pounds of engine/trans settling back into place can often be felt.
Also check the bolts holding the engine/trans together plus the bolts on the flex plate. Something loose/worn in the rear end/spring shackles? |
05-21-2021, 06:01 PM | #9 |
Like has been suggested I would remove the driveshafts and check out the U joints.
05-23-2021, 10:04 AM | #10 |
Thread Tools | |
Display Modes | |
