05-22-2021, 08:03 PM | #1 |
Active Member
Bbc pulleys?
I'm putting a 71 402 chevelle motor in my Blazer, it has air conditioning, what pulleys will I need for the water pump, crank, and power steering any help would be greatly appreciated, thanks Adam
05-23-2021, 05:20 PM | #2 |
Re: Bbc pulleys?
69-72 Chevelles have the long water pump. So to keep the truck setup you will need a short water pump. The pulleys and brackets from a 66-68 Big Block Chevelle will work. Crank, water pump, power steering bracket/pump/resevoir and alternator.
FYI, this will be a significant expense if you were hoping to do a cheap big block swap. A lot of people keep the long water pump pulleys and brackets, but I prefer spending the money for the short pump setup.
05-23-2021, 08:38 PM | #3 |
Re: Bbc pulleys?
05-27-2021, 09:53 PM | #4 |
60-66 Nut
Re: Bbc pulleys?
All trucks '72 and earlier came from the factory with short water pumps. That's what I prefer to run in the '72 and earlier trucks. Then you can run '68-'72 truck big block components or '65-'68 car big block components.
05-28-2021, 01:43 PM | #5 |
Re: Bbc pulleys?
http://67-72chevytrucks.com/vboard/a...1&d=1380395872
You might want to look into this setup from kwik performance, they make a really nice kit for the bbc . This is from my build thread, they use sbc SERP mounts and fit is awesome, I’m very happy with it.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! Last edited by crossfire84; 05-28-2021 at 01:51 PM. |
05-28-2021, 01:52 PM | #6 |
Re: Bbc pulleys?
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
Thread Tools | |
Display Modes | |
