05-24-2021, 11:48 PM | #1 |
Electric choke wiring
I have an 87 C10 (R10). I want to hook up an Edelbrock carb electric choke. I replaced the electric oil pressure sender with a mechanical gauge. Can I use the wire fore the old wire pressure sender to power the electric choke? If not, what is the easiest way to get power to the choke?
05-25-2021, 12:11 PM | #2 |
Re: Electric choke wiring
The oil pressure sender would not be a good choice. Any 12v source that's on when the engine is running would work.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-29-2021, 10:12 PM | #3 |
I tapped into my wiper motor with a wire tap (blue thingy)
05-29-2021, 10:13 PM | #4 |
I also added a fuse
06-01-2021, 01:01 PM | #5 |
My '70 C10 fuse box had two (unfused) terminals that were activated by the ignition switch. I used one for my HEI and one for electric choke. I used inline fuses for both. Pretty easy connection, and Amazon had nice inline fuses.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
Thread Tools | |
Display Modes | |
