06-14-2021, 01:34 AM | #1 |
T400 help please
I have a 383 with a T400 transmission and BTE 310800 11” converter Stall Speed 2600-2800 rpm.
On my last drive the trans would not shift until it reached 4000rpm. What could be going wrong? What should I look for? Thank You |
06-14-2021, 06:08 AM | #2 |
Re: T400 help please
Check the vacuum line for full vacuum.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-14-2021, 11:25 AM | #3 |
Vacuum line most likely---OR the governor (under the 4 bolts on the side) has stripped a gear from the bushing walking in the case
06-15-2021, 12:42 AM | #4 |
Thanks guys, I know the vacuum line is hooked up but, what's the best way to test it?
06-15-2021, 01:22 AM | #5 |
Hook a vacuum gauge to the line at the trans
06-16-2021, 10:39 AM | #6 |
I had same issue bit I had my vacuum advance cannister off the HEI T-d into it. The diaphragm in the cannister went bad and raised my shift points like you.
06-16-2021, 11:25 AM | #7 | |
I'll get a chance to look at it this weekend. Hopefully its just a line that came unattached. |
06-20-2021, 08:51 PM | #8 |
Well, I tested vacuum at the transmission it was 20-22 at 3000rpm. Does that sound about right?
Then I checked the kick down switch and it was stuck on. I took the Lokar switch apart and sprayed it with silicone lube. That seems to have done the trick. All is well now, thanks for the help. |
