Old 07-10-2022, 07:35 PM   #1
pontiacvince
pontiacvince's Avatar
Fuel problem
Not sure what my problem is, but I cannot get fuel from the tank to the carb. I have been filling the bowl through the vent tube about 20 tomes. It fires up and runs fine and sounds DAMN GOOD with the Flowmasters on the headers.....until the bowl runs out. I have chased all of the lines from the tank to the pump and can't find any leaks. The vent line runs from the vent tubes in the back to the canister on the fender.
Any ideas???
pontiacvince is offline   Reply With Quote
Old 07-10-2022, 09:20 PM   #2
BAD1916
Re: Fuel problem
I would disconnect the line from the tank to the fuel pump and make sure you are getting fuel there. I would also disconnect the line from the fuel pump to the carb. If you are getting fuel there there’s something clogged in the carb. If not and there was fuel at the input to the pump then the pump is most likely your problem. I have had issues on old thunderbirds where we weren’t getting fuel and we had to pressurize the fuel tank by using air from a compressor and blowing it into the fuel filler.
BAD1916 is offline   Reply With Quote
Old 07-10-2022, 10:32 PM   #3
pontiacvince
Re: Fuel problem
I went through all of my lines this morning. I installed a 40gal. tank with new sending unit, and all new lines front to back.
I pulled the pump and still no fuel. The pump rod is working.
Old 07-10-2022, 11:35 PM   #4
BAD1916
Re: Fuel problem
Have you tried running a hose into a gas can to verify that the pump is functional. Even if it’s new doesn’t mean it’s good.
Old 07-11-2022, 01:08 AM   #5
pontiacvince
Re: Fuel problem
I'm gonna pressurize the tank tomorrow to verify the lines aren't plugged. Then I'll test the pump.
Old 07-11-2022, 03:32 PM   #6
kwmech
Re: Fuel problem
Fuel line to the pump is incorrectly hooked up at the tank??
Old 07-11-2022, 07:39 PM   #7
HO455
HO455's Avatar
Re: Fuel problem
Have you replaced the 6 inch loop of hose inside the frame rail just in front of the crossmember (on a T400 truck)? That hose will go bad and the pump will only suck air. It won't leak fuel unless you pressurize the line.
I replaced mine with a short piece of steel line and 2 compression fittings. See photo.
I bent my lines straight but they have 90 degree bends where the hose attaches from the factory.
RIP Bob Parks.
Old 07-15-2022, 02:08 PM   #8
pontiacvince
Re: Fuel problem
I pressurized the tank and pushed the fuel to the front. Problem solved!
Old 07-15-2022, 02:31 PM   #9
HO455
HO455's Avatar
Re: Fuel problem
Good to hear.
RIP Bob Parks.
Old 07-15-2022, 07:09 PM   #10
nightmare
nightmare's Avatar
Re: Fuel problem
Until you run out of fuel. You may have a problem with the pump not being able to suck the fuel all the way to the front. You may either have a bad fuel pump, or need to make sure you pressurize the tank every time you fill up
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 07-15-2022, 07:32 PM   #11
pontiacvince
Re: Fuel problem
So far, after breaking in the engine and running it to check everything, it runs and sounds really good. Excellent oil pressure, and great vacuum. Hasn't overheated. Bled the air out of the new power steering pump and steering gear. I put the Flowmasters directly on the headers and it sounds REALLY good! Can't wait to get the full exhaust on.
