Old 07-27-2010, 02:08 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Which oil pan for 72 GMC 2wd?
I have a 72 GMC truck and am in the midst of rounding up parts for to install a 6.0 LQ4 that came from a 01 Chevy truck. What oil pan will fit mine? I have seen that some guys have to change to the Caddy CST V pan.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 07-27-2010, 02:12 PM   #2
LEEVON
LEEVON's Avatar
Re: Which oil pan for 72 GMC 2wd?
I'm using an f-body pan just for extra ground clearance.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 07-27-2010, 02:21 PM   #3
MONTEZ
MAST motorpsorts has one coming out in a few weeks that will fit darn near any application, pretty much universal.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 07-27-2010, 02:24 PM   #4
Ackattack
Ackattack's Avatar
I used an F-body pan for mine.
the truck pan will work, but hangs down below the crossmember.
Ackattack is offline   Reply With Quote
Old 07-27-2010, 02:40 PM   #5
Jim_PA
The truck pan hangs down less than an inch with the ECE mounts.
Jim_PA is offline   Reply With Quote
Old 07-27-2010, 02:49 PM   #6
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
GM part number 19212593, universal oil pan kit, fits all Gen III and IV engines (not a direct fit for the LS7, LSA, and LS9) and includes the oil pan, gasket, indicator tube and indicator, pickup tube and crankshaft oil deflector.
$120.96.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-27-2010, 03:52 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I already have the ECE motor mounts and plan on using them, I also have air ride and my front crossmember is only 2" above ground aired out. Thanks guys!!!!
Old 07-28-2010, 09:49 AM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
If I change to a F body pan will the p/u tube also need to be changed?
Old 07-28-2010, 10:20 AM   #9
Ackattack
Ackattack's Avatar
yes, and windage tray, and dipstick.
Old 07-28-2010, 02:44 PM   #10
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Originally Posted by glock35ipsc View Post
gm part number 19212593, universal oil pan kit, fits all gen iii and iv engines (not a direct fit for the ls7, lsa, and ls9) and includes the oil pan, gasket, indicator tube and indicator, pickup tube and crankshaft oil deflector.
$120.96.
+1
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 07-28-2010, 02:47 PM   #11
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
cool thanks backyard88.
Old 07-29-2010, 02:12 PM   #12
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Originally Posted by BACKYARD88 View Post
+1
Does this come with the oil cooler block off plate? Are you guys running an oil cooler? Is it needed?
Old 07-29-2010, 04:42 PM   #13
Jim_PA
Don't know if it comes with a block-off or not, but I put a corvette style adapter on there, and tapped it for a mechanical oil pressure gauge.
Old 07-30-2010, 02:29 PM   #14
BACKYARD88
BACKYARD88's Avatar
Mine came with the block off plate already on the pan. I don't see a need for an oil cooler on my application.
-Mike Owen-
Old 07-30-2010, 06:08 PM   #15
68 c10 ls2
68 c10 ls2's Avatar
I dont know the part number but its called the "LS SWAP OIL PAN" you can get it from Jegs, Summit or GM. It come with evey thing you need. Bolts, gasket, p/u tube and it does have a bolted on block off plate for the oil cooler. You shouldnt need an oil cooler unless your towing, or have a superchager/turbo on your motor. I also have the ECE motor mounts and it may hang 1/4" below the cross member but thats where the drain plug is. This pan is off an 08 Hummer H3. So thats the oil filter you need to ask for when you go to change your oil.
68 c10 ls2 is offline   Reply With Quote
Old 07-30-2010, 08:25 PM   #16
glock35ipsc
Originally Posted by 68 c10 ls2 View Post
I dont know the part number but its called the "LS SWAP OIL PAN" you can get it from Jegs, Summit or GM. It come with evey thing you need. Bolts, gasket, p/u tube and it does have a bolted on block off plate for the oil cooler. This pan is off an 08 Hummer H3. So thats the oil filter you need to ask for when you go to change your oil.
As posted above in post #6.
$120.96.
Bob
Old 08-01-2010, 10:31 PM   #17
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Yep, I ordered the GM 19212593 from www.gmpartsdirect.com the other day. It has shipped, so hope to have it Tuesday.
Old 08-01-2010, 10:35 PM   #18
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I assume that it's pretty accurate being that it is placed there? So, you are not using the electric gauge?
Old 08-04-2010, 09:39 PM   #19
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
$120.96.
So what oil filter fits this pan? I already purchased a filter to fit the old pan. 01 6.0 LQ4 filter doesnt fit this pan. Another trip to the parts store with pan in hand.
Old 08-04-2010, 09:49 PM   #20
glock35ipsc
ACDelco PF-48
Bob
Old 08-04-2010, 09:56 PM   #21
Jim_PA
I have the sender hooked up to the PCM (not that it's needed...), but am using a mechanical gauge for the cab. I don't see why it wouldn't be accurate in that spot.
Old 08-04-2010, 09:58 PM   #22
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
ACDelco PF-48
Thanks Glock!! You are a Gentleman and a Scholar.
Old 08-24-2010, 08:08 PM   #23
Hart_Rod
Hart_Rod's Avatar
You could always take the fitting out of your old pan and install it in the new pan. I did that on mine so I can always get parts that fit the truck (tahoe) that my motor came out of.
R/
Hart_Rod is offline   Reply With Quote
