10-01-2019, 12:47 AM | #1 |
LS Wire Harness Connectors
Is there a list of part numbers for the connectors on a ls harness? I have more than a few broken connectors on a harness that I need to replace.
10-01-2019, 09:30 AM | #2 |
Re: LS Wire Harness Connectors
for the two or three that were wonkey on mine I just went to the local PnP and snipped them off of the harness, I made sure not to jack up a good one so I found some that were already torn apart, I figured better to replace OEM connectors with OEM rather than aftermarket junk, but simply Google it we find EFI:
https://www.eficonnection.com/home/c...ors/connectors |
10-02-2019, 09:38 PM | #3 |
efi connection is great for replacement connectors. You can get empty bodies and pins as well as pigtailed connectors if you don't have the right crimp tools.
10-03-2019, 09:16 AM | #4 |
Mouser Electronics is the place but you will need to know the Delphi part numbers.
10-03-2019, 02:39 PM | #5 |
An Alldata subscription for your donor vehicle will give those part numbers. At least it worked on my 2010. There's numbers listed for each connector and terminal.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-03-2019, 03:37 PM | #6 | |
https://ls1tech.com/forums/conversio...rs-inside.html Here is a link to the Delphi parts catalog. It doesn't show specific applications, but it does give part numbers. https://www.reynoldsonline.com/ASSET...4580L_Broc.pdf Last edited by Willie Makeit; 10-03-2019 at 03:45 PM. |
10-03-2019, 03:46 PM | #7 | |
https://www.powerandsignal.com/docs/...%20Catalog.pdf Edit: Jinx! Willie found another catalog scan at about the same time. |
10-03-2019, 04:06 PM | #8 |
dayj1 is from whom all knowledge is gained.
10-08-2019, 01:52 PM | #10 |
67see10, for gen 3 LS right?
10-08-2019, 02:52 PM | #11 |
