Old 01-13-2020, 03:28 PM   #1
G-NUT
G-NUT's Avatar
anyone modify stock A/C to work with bagged truck
Anyone modified stock A/C to work with their bagged squarebody truck, blazer, burb? I'm in process of installing Porterbuilt front and rear Dropmembers on my 84 burb. I'm running 22 inch front / 24 inch rear wheels.
I know I've already spent a ton of money on it, taken 5+ years, so I'd like to save the $1,300+/- that an aftermarket A/C system costs and try to keep my stock A/C if possible.
Wondering if anyone had managed to do this so the front right wheel doesn't hit the A/C system?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 01-14-2020, 10:29 AM   #2
SunSoaked
SunSoaked's Avatar
Re: anyone modify stock A/C to work with bagged truck
22 inch front wheel? I guess you'll be dropping another $1500 on the Vintage Air. I have it. It works great.
SunSoaked is offline   Reply With Quote
Old 01-14-2020, 10:57 AM   #3
SCOTI
SCOTI's Avatar
What front tire OD/size?
THE Dropmember moves things forward so that helps. My dually w/a 1.5" notched front x-member in the stock location runs 29" fronts & clears the A/C box/blower motor. Some creativity could locate the blower motor higher as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
a/c, bagged
