Old 09-19-2020, 01:08 AM   #26
clinebarger
Re: Transmission lines 4L60e to stock 71 rad cooler
Originally Posted by sprint_9 View Post
Inlet is the bottom, you want to push fluid up so it fills the void, if you go in the top it will just fall through and might not fill the cooler.
Incorrect.....At the Radiator....The top is the Inlet & the bottom is the Outlet.
clinebarger is offline   Reply With Quote
Old 10-13-2020, 04:15 PM   #27
A1971Blazer
A1971Blazer's Avatar
which one is the inlet/return at the transmission (4L60E)...?
Everything I've found by searching says top is the return...
Just want to be sure
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
