Old 10-02-2021, 02:59 PM   #1
forestb
forestb's Avatar
Breather filter material
I have a breather on my valve cover that you can take apart. Inside there is a filter material that looks a lot like the material that is inside a fuel cell that keeps the gas from sloshing around. It is starting to fall apart. I there something that I can replace it with. It is shaped like a donut but it doesn’t have anything that goes through the canter. It is inside an empty cavity.
forestb is offline   Reply With Quote
Old 10-02-2021, 03:23 PM   #2
Ziegelsteinfaust
Re: Breather filter material
Didn't they just use to use thick steel wool for that too?
Ziegelsteinfaust is offline   Reply With Quote
Old 10-02-2021, 03:23 PM   #3
geezer#99
geezer#99's Avatar
I stuffed some steel wool inside one once.
You can buy steel wool at the grocery store or hardware.
Old 10-02-2021, 03:33 PM   #4
forestb
forestb's Avatar
That sounds risky. I would be afraid that it would get into the oil. I have steal wool. What grit would you recommend
Old 10-02-2021, 03:46 PM   #5
forestb
forestb's Avatar
Do you think it would work to put the stuff that is inside a fuel cell. I have plenty of that
Old 10-03-2021, 11:03 PM   #6
AcampoDave
AcampoDave's Avatar
My breather has a spongy foam filter inside. It's probably polyurethane like this.... https://unifilter.com/online-catalog...n-air-filters/ seems if polyurethane is good enough for them it should work for you too. Here's a little block of it on Amazon https://www.amazon.com/Sculpture-Blo...a-841373556131
AcampoDave is offline   Reply With Quote
Old 10-03-2021, 11:35 PM   #7
forestb
forestb's Avatar
Found this on Summit. Pretty inexpensive.
Looks just like the one that is in there.
https://www.summitracing.com/parts/bsp-rp2010
