09-30-2013, 02:44 PM | #1 |
73-87/91 motor/engine stands??
I'm in need of the engine bracket or stand from a 73+ C10. I'm not sure exactly what they're called or if this is the appropriate place to post this? Let me know if you have a set for sale or know where I can buy them please. Thank you!
-Joe Posted via Mobile Device
1986 IROC-Z lS1/T56 Moser 9" 78mm Turbo 1968 C10 step side, 5.3 Maggnacharger TVS1900 6L80E 2009 CCSB 5.3/6L80 4x4 http://members.cardomain.com/gflo383 |
09-30-2013, 04:45 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 73-87/91 motor/engine stands??
Clam Shell is what they are called, I dont have any, sorry
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-30-2013, 09:21 PM | #3 |
I can see if i can find a set. Best place to try would be a WTB in the 73-87 section
09-30-2013, 09:43 PM | #4 |
88-98 stands work as well, RWD sbc passenger cars 'till '94 also work, The Driver side stand is the same on LT1/L99 '94-'96 B-bodies.
These should be readily available.....I've thrown several sets away because their so common. |
09-30-2013, 10:58 PM | #5 | |
60-66 Nut
I assume you are talking about the brackets that go between the front crossmember and the top of the frame on each side? If so, what ssize of truck are you working on? The brackets for a C10 are different than the brackets for a C20 or 30
10-04-2013, 02:36 AM | #6 |
Captain, about your statement above, I just put 73 C30 purches on my 73+66 C-30 frame. They look the same as the C-10 IIRC. I'm hoping the swap will end to the same function, an LS1 with DD or like adapters.
How do the purchases differ between the C-10 and C-20/30? Dave. Last edited by 65 wonton; 10-04-2013 at 02:47 AM. |
10-04-2013, 08:37 PM | #7 |
The C20/C30 frame stands sit the engine higher than small block chevy C10 frame stands. Big block C10 frame stands could be the same as C20/C30.....Not sure maybe Captain has more info.
10-05-2013, 12:56 AM | #8 |
60-66 Nut
I don't remember the specific dimensions off hand but the '73+ C10 frames are taller than the '63-'72 frames, where the motor mounts are located. The '73+ C20 and C30 frames are very close in height to the height of the '63-'72 frames. The brackets do look identical, but dimensionally they are different. Consequently they are better candidates when upgrading the early trucks to the better clamshell motor mounts.
