05-07-2021, 10:23 AM | #1 |
Extended Oil Fill Tube Securing Bolt ?
I removed this to gain access for HEI install. 2 Questions, can you use a regular oil cap in the present valve cover grommet , is the bolt necessary or replaced with shorter version ? Thanks
71 C-20 07 Magnum RT AWD |
05-07-2021, 11:00 AM | #2 |
Re: Extended Oil Fill Tube Securing Bolt ?
You can use the same cap to plug the valve cover that is on the top of that. you'll need a 1/4'' shorter bolt to go in the hole you pulled that out of since it helps seal the intake manifold.
05-07-2021, 11:47 AM | #3 |
Yup- same rubber oil plug on the top of the fill neck will fit in the valve cover.
Curious why you had to remove it for installing HEI- I had one of these on my '72 K5 Blazer and had no issues with clearance or accessing the distributor.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
05-07-2021, 02:11 PM | #4 |
I removed everything on that side so I could remove the valve cover to help find TDC #1 plug. Also cleaning up everything for paint. I will reinstall it after I finish the job...thanks for the information guys !
