06-22-2021, 03:44 PM | #1 |
Robert Olson Transport
350 Motor differences
So my own truck is a 98 K 2500 GMC and the lower end of the motor started going and last drain there was a decent amount of metal in the oil so it was time for a motor.. I had a motor i pulled last year from a 97 Tahoe 1500 4wd and as i got my motor out i noticed some differences starting with the truck motor has an extra threaded hole at the top of the bellhousing... is there a difference between these two motors mechanically? ( i also had a HD oil cooler on mine and mine was purchased as a municipality truck)
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
06-22-2021, 05:09 PM | #2 |
Re: 350 Motor differences
the 2500 had a beefed up motor compared to the 1500.
The 2500 has 4 bolt mains, forged crank, hypereutectic pistons where the 1500 has 2 bolt mains, cast crank, and cast pistons. Compression and cam specs are essentially the same. You can swap it in but know that it's designed for lighter use.
Mike |
06-23-2021, 05:41 AM | #3 |
Huh, I never knew that.
06-23-2021, 12:31 PM | #4 | |
The heads are different on my 93. Not sure if they are on those though.
06-23-2021, 02:42 PM | #5 | |
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
06-25-2021, 01:24 PM | #6 | |
Mike |
06-26-2021, 01:26 AM | #7 |
All about them K’s
There’s a difference in the heads too, the heavy duty motor uses different valve seats too if I remember correctly. I don’t believe it’s cut and dry based on GVW but I do agree 8600+ Is more likely to have the HD motor.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
06-26-2021, 07:28 AM | #8 |
i can find out. need to replace the motor in my yukon, got one from a crew cab short box C2500. It was the light duty, had the 14 bolt semi float. Looked up casting number and says 2 or 4 bolt. I need to replace the oil pan.
