Originally Posted by RichardJ
[COLOR="Red"]>
72SB, none of that is true.
Unfortunately you are wrong. Believe what you want. External ballast and resistor wires are for points dizzy.
Pertronix specifically says in any of their units to eliminate resistor wire if converting over to points. There are several threads on this forum about replacing the resistor wire for HEI be it a GM unit or Pertronix. Read up
Agreed lower voltage will not "immediately" kill a HEI module...but it will after time
