10-22-2021, 09:31 AM | #1 |
Seam Sealer ?
What is a good seam sealer to use? I need to do the top of my rain gutter
on my cab and inside the step area of the cab also, looking for suggestions. Thx,Allen |
10-23-2021, 06:57 PM | #2 |
Re: Seam Sealer ?
Many folks use a self-leveling 2K seam sealer for horizontal areas like the drip rail. I haven't done it yet.
I did the underside of my cab in ordinary SEM 2K Seam Sealer. No complaints.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
10-26-2021, 04:08 PM | #3 |
Re: Seam Sealer ?
Self leveling is what you want for drip rails, it will flow and level out to a glass-smooth finish that only needs scuffing before sealer/paint. It's too thin for normal seams so you'll want a normal seam sealer for that. Two part sealers are best, they won't shrink later. I like Fusor 122ez for drip rails and SEM 39377 for other seams.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
10-27-2021, 09:11 AM | #4 |
Re: Seam Sealer ?
After you remove the old seam sealer I would suggest a good acid etch prior to priming. Soak the seam for a day or two. Use a paintbrush to apply to metal prep into the drip rail. After it dries prime it, and go from there.
10-27-2021, 10:19 AM | #5 | |
Re: Seam Sealer ?
Allen |
10-27-2021, 10:21 AM | #6 | |
Re: Seam Sealer ?
Allen |
10-27-2021, 10:24 AM | #7 |
Re: Seam Sealer ?
Very good
10-27-2021, 10:30 AM | #8 |
Re: Seam Sealer ?
Question ? Using the Fusor & SEM Products do i need to buy two seperate Caulking guns
OR, will the SEM 71119 Caulking gun work for both? Suggestions? Thank you again! Allen |
10-27-2021, 09:19 PM | #9 |
Re: Seam Sealer ?
Fusor is in the "change-over" phase to the smaller tubes like the SEM. as long as you purchase the new short Fusor tubes you will be good. Lorne
10-28-2021, 09:28 AM | #10 |
Re: Seam Sealer ?
Eastwood seam sealer uses a regular caulking gin . Your cab has to be level and
the self leveling sealer sets up fast so you need to be ready to do it all in less than 5 minutes . if you use masking tape be ready to remove it as soon as possible once the sealer sets the tape will be very hard to remove https://www.youtube.com/watch?v=_yCa9zzkMvo http://67-72chevytrucks.com/vboard/s...=783262&page=2 https://www.eastwood.com/ew-2k-self-...cartridge.html https://www.youtube.com/watch?v=CbuvdY0lzTg Watch all the stout customs videos . https://www.youtube.com/c/StoutCustom/videos
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 10-28-2021 at 09:42 AM. |
10-28-2021, 03:38 PM | #11 |
Re: Seam Sealer ?
How is 3M seam sealer?
