Old 09-30-2021, 11:50 AM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
6l90 trans TC question
I have recently learned about the issues with the torque converter in the 6l80/90
did chevy fix the issue in later years? meaning is there a date range where you should swap the TC out when doing an install?
is they have not. what is the recommendation for a TC that will prevent that problem? I have a swap ready to go in the truck, this is the time to swap it if I need to. the donor 2018 with 9k miles on it, so id rather leave it alone.
perhaps an inline filter to the cooler?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-30-2021, 12:17 PM   #2
mtdave2
mtdave2's Avatar
Re: 6l90 trans TC question
I did notice the TC part number did change in later years, 2014 or so?
24245962 vs 24217235 express vans
29549522 for 2008 Silverado
24245962 for 2010 Silverado
69 k10 Suburban
Old 10-03-2021, 04:21 AM   #3
87Skier
87Skier's Avatar
What issue are you referring to?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 10-04-2021, 10:18 AM   #4
mtdave2
mtdave2's Avatar
the TC slips and sends the material through the trans.
https://www.sonnax.com/tech_resource...r-next-rebuild
69 k10 Suburban
Old 10-04-2021, 03:44 PM   #5
87Skier
87Skier's Avatar
Thanks for the link. One aspect Sonnax didn't discuss is programming on the torque converter. I have HP tuners and have messed with the 6L90 and 4L60. The configuration of the 4L60 is significantly easier with many fewer options. For example, the 4L60 uses a TCC duty cycle, whereas the 6L90 uses a desired slip RPM.
When I did my swap in 2017-2018 I bought a 6L90 with about 50,000 miles on it and noticed a significant amount of clutch material in the pan and tore down the entire transmission checking the rest of the clutches. I ultimately decided to replace the torque converter because everything else looked good.
To alleviate some clutch wear I changed how the torque converter is used during driving. I completely disabled it in 1st and 2nd gears, and reduced the amount of desired slip under normal driving. I bumped up the pressures for the rest of the gears. I also disabled it completely under high load and high RPM situations. Most of the changes I made were from recommendations of the HP tuners forum.
I have put about 15k to 25k miles on it since the swap, so I haven't had the pan off yet to determine if the changes I made have resulted in less torque converter wear.
If I were you I would probably keep what you have in there. I also wouldn't bother with an inline filter because once the torque converter friction material is gone, it's metal on metal and the filter won't help. I would just keep an eye on the amount of friction material in the pan during regular servicing and if it is excessive consider replacing the torque converter after 100k miles.
