10-18-2021, 08:33 PM | #1 |
Anyone wanna help me decipher this gear pattern?
I am regearing a Dana 30 front end (not a c10, it's a Jeep)
Went from 4.10s to 4.88s, I'm having a pretty steep learning curve, to say the least. I shimmed the pinion to get the pattern deeper into the ring. at .048 it was exactly the same pattern, just a bit deeper. I removed some shims, this is with the pinion shimmed @ .042 Seems to be centered but the pattern is very narrow. backlash is perhaps on the tight side @ .006 but it is in spec. My hunch is that the pinion is too deep??? ...If so how much(ish)? I would really appreciate some input from someone with some experience.
Insert clever text here: |
10-18-2021, 09:18 PM | #2 |
Re: Anyone wanna help me decipher this gear pattern?
seems a little too far in from what I,ve seen on gear patterns when I did mine. Pic. might be a little deceiving for me . I,m sure someone will chime in soon
10-18-2021, 09:31 PM | #3 |
Yeah, my camera kinda sux. I'll try to get some better pics. I am concerned about how narrow the pattern is.
10-18-2021, 09:55 PM | #4 |
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
10-18-2021, 10:55 PM | #5 |
that looks pretty deep yes, If it were me I'd make a .010 change (move pinion farther away from ring) and re check w/ same backlash
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
10-19-2021, 03:04 AM | #6 |
So... Yeah, that was deep. I walked the pinion back .040" (no, that's not a typo) and it's starting to look like a recognizable pattern. I'm learning.
10-21-2021, 01:09 AM | #7 |
woah, yeah deep....I was guessing making changes at .010 or more... I end up trial and error method since I don't have the depth measuring tools.
