Old 10-02-2008, 12:05 AM   #1
Thorbecke Bros.
$550.00 Raised Crossmember Special!
We will be selling the raised crossmember starter kit for $550.00 during the month of October. You can place your orders now if you wish. All you need to do is call us up at 812-782-3581 to place your order. We do not want any money now. Not even a deposit. Once your kit is ready to ship we will call you to finalize all the details. We are expecting to start shipping kits around the 1st of November. We have a few more tests to perform to make sure all is good and ready.
The Starter Kit includes the following....
*Main Crossmember
*Upper Bag/Control Arm Mounts
*Inner Frame Gussets
*Rack & Pinion Frame Notches
*Engine Mounting Tabs
*Grade 8 Mounting Hardware
We are offering this version of the kit for the person who can fabricate, and would like to locate their engine and build their own engine mounts. Its a good kit to get you started.
$550.00
[IMG]http://www.*****************/jason/images/c.assbly10.jpg[/IMG]
Thorbecke Bros. is offline   Reply With Quote
Old 10-02-2008, 12:16 AM   #2
spr85gmc
spr85gmc's Avatar
Re: $550.00 Raised Crossmember Special!
y not just put the engine mounts and be done with it it would sell alot faster being many donbt have time or skill to do it themselves...
spr85gmc is offline   Reply With Quote
Old 10-02-2008, 01:13 AM   #3
FnLow69
FnLow69's Avatar
and were are the engine mounts, i see the mounting tabs....
FnLow69 is offline   Reply With Quote
Old 10-02-2008, 01:44 AM   #4
Rokcrln
Rokcrln's Avatar
Don't you actually want to road test one before you release a "new to you " product? What is the preferd caster and camber #'s for your kit?
Rokcrln is offline   Reply With Quote
Old 10-02-2008, 06:36 AM   #5
lowdownstar
big guy
lowdownstar's Avatar
ok help me out here, what is the difference from the $700 kit and this one? just welding up the motor mounts? Or am i missing something? Can some one show some pic's of how all this looks on a truck. What are the benefits of a drop member and is it only for guys wanting to lay frame? Thanks Ray
lowdownstar is offline   Reply With Quote
Old 10-02-2008, 09:06 AM   #6
aggie91
I'm just glad to be here!
aggie91's Avatar
X2
What is the ride/handling like? Other products that are available have some road time and feed back as to the ride of the truck after the install.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-02-2008, 11:01 AM   #7
jasonb72
PorterBuilt Man Crush
Hers are the other quotes
we will be offering everything listed below during october for $700.00. it will jump to $999.00 after that. we are doing an introductory special.
$700.00 gets you......
1. main crossmember
2. upper bag & control arm mounts
3. inner frame structure brackets
4. rack & pinion frame notches
5. transmission crossmember
6. 350 engine mounts
7. stainless tie rod adjusting sleeves
8. chromoly/teflon 3/4" x 5/8" heims for the spindles
9. all grade 8 mounting hardware
$1500.00 gets you......
1. everything listed above
2. upper and lower control arms
3. upper frame shock mounts
4. monroe shocks
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 10-02-2008, 11:54 AM   #8
lyrikz
PITbut
lyrikz's Avatar
Uhhh, kev, did you miss this part? "We have a few more tests to perform to make sure all is good and ready."
Im sure its being tested.
lyrikz is offline   Reply With Quote
Old 10-02-2008, 12:10 PM   #9
Bazooka
Keepin it old school
Bazooka's Avatar
I think he missed this part too..
Bazooka is offline   Reply With Quote
Old 10-02-2008, 02:44 PM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet, I just got off the phone with yall & I'm "In"
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-02-2008, 06:03 PM   #11
Bazooka
Bazooka's Avatar
Awesome! The guy thats doing the air ride on my truck (Method Motor Works. Fresno, Ca.) told me he's going to call in tomorrow and order
Old 10-02-2008, 06:34 PM   #12
Wild83C10
Wild83C10's Avatar
The $700 kit sounds like a better deal then this kit.
The trans x-member, engine mounts, tie rod ends and hiems are worth more then $150.
Does this crossmember retain the stock suspension geometry?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 10-02-2008, 07:48 PM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Along with the geometry question
I remember reading that the Porter Built Drop Member, has a narrower track width, does this one too ???
Sinister
Killer
Old 10-02-2008, 09:21 PM   #14
lowdownstar
big guy
sorry i was wrong to go after you i didn't know you were not a part of SD
Old 10-02-2008, 09:45 PM   #15
Bazooka
Bazooka's Avatar
Jasnb72
If you really want to sell ME a drop member then please answer my question with a little respect. I don't know you guys from a hole in the wall and if i don't ask the right question or say it the right way i am sorry but please don't treat me like an ass! thank you
I also asked Can some one show some pic's of how all this looks on a truck? i am sure you have this installed on a truck so you know it fits and works well together, "right". What are the benefits of a drop member and is it only for guys wanting to lay frame? Thanks Ray
I hope your not the one doing customer service for SD!
Thats not Jason from SD
Old 10-02-2008, 09:52 PM   #16
SCOTI
SCOTI's Avatar
Dropmember = Porterbuilt Streetrods
Raised Crossmember = Suicide Doors
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-02-2008, 10:05 PM   #17
Shane
Shane's Avatar
Another dang good example of why you guys should relax and let the vendors answer the questions on their own product.
I'm trying my best to give you guys friendly advice the nicest way I know how.
Shane is offline   Reply With Quote
Old 10-02-2008, 10:25 PM   #18
68 short step
68 short step is offline   Reply With Quote
Old 10-02-2008, 11:15 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Shane is correct. If you are not Jason, or a "qualified" employee of SD DO NOT take on the responsibility of answering questions.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-02-2008, 11:32 PM   #20
jasonb72
Not sure what the problem with my post was, you asked a question I clipped some info you asked for from the other thread and posted for you to see.
I guess I should have taken out the section that made it seem I was with SD. Not sure how that is being an ass.
I am not one to get into these pissing contest, just trying to help people get the info they asked for. I have no affiliation with SD.
Moderators, I can understand your point of letting the vendors answer their own question, but their are vendors that do not log on and check post for days, and it always seems to be the case that board members and moderators go out find the info from other threads and post it. Maybe the posting rules need to be updated to include this.
Jasnb72
Old 10-03-2008, 12:46 AM   #21
Rokcrln
Rokcrln's Avatar
No I saw both of those,what confused me was a company Advertising new suspension parts before they have any possible kinks worked out. I under stand wanting to gauge the market before wanting to put out the money and time to build all the raised members but it just seams back wards to me. I have been around customs and Hot Rods my entire life and have seen this bite company's in the A$$ allot. I hope this does not happen here.
This DropMember and raised member is no different than what happened with the MII front ends when they first came out. We used to cut out factory cross members and use them in our rods (told you I've been around awhile) then the first "New cross member" was offered, then they started popping up everywhere you looked. The guys that did their home work and testing and then started selling them are Still out their and the other guys are who knows were now. My main concern is safety we are talking about suspension, steering and brakes lets just make sure it is 100% right before they start being sold.
Kevin
LFD Inc.
Kevin
LFD Inc.
Old 10-03-2008, 06:44 AM   #22
lowdownstar
big guy
Smile Re: $550.00 Raised Crossmember Special!
Jasonb72
I am sorry for what i said i thought you were part of SD and i was a little upset on how a company would not take the time to answer all my questions and just show me another add. you were just being helpfull and i am sorry!
I really didn't know you were not apart of SD......
sorry again
thanks for your help
Ray
Old 10-03-2008, 08:00 AM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by jasonb72 View Post
Moderators, I can understand your point of letting the vendors answer their own question, but their are vendors that do not log on and check post for days, and it always seems to be the case that board members and moderators go out find the info from other threads and post it....
That is true, and in most cases is just fine. Since there has been so much controversy recently I am encouraging everyone to let the appropriate parties be responsible for answering the questions.
Articles-
"Refining Sierra"
Old 10-03-2008, 08:34 AM   #24
SCOTI
SCOTI's Avatar
Jasonb72
sorry again
Ray
You get an 'atta-boi' in my book for the public apology!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-03-2008, 09:13 AM   #25
jasonb72
Not a big deal, I do appreciate you responding this way.
Jasonb72
sorry again
Ray
