Old 02-08-2012, 07:17 PM   #1
jeffg1010
jeffg1010's Avatar
So... do you want gas struts on your barn doors?
I just finished mine. And after seeing how easy it was, I am ashamed at how long it took me to get it done. There is threads on here dedicated to putting gas struts on liftgates (clam shell doors), but I couldnt find anything with info on how to do it to barn doors, so here it is.
Part #'s and prices are at the very bottom of this post.
This project only takes about four steps and it will LITERALLY take you less than 30 minutes to do it. (if you had everything ready to go, you could have it done in 10)
Mine on the other hand, took about 4 weeks. But, I had to learn a few things and find the right parts to use. SO, you can learn from my experience.
So... I have a '70 Burb with the factory sliding mechanisms that hold the doors open. I've gotta say... I've hated these things from day 1. The first scratch I put on my Burb after it was painted was on the barn doors. I had them open and a big wind came along... slammed the right one first and then the left. (the opposite of how they are supposed to close) and it nearly gave me a heart attack when I saw my paint get screwed up. BUT OH WELL... old news.
So...
STEP 1: Remove those old sliding mechanisms. Its simple. You need a medium sized Phillips screwdriver. There is 2 screws on each end (4 per slide-8 total)
STEP 2: Install the 10 mm ball stud x 1/4-20 male thread Ball Studs onto the door and into the roof of the Burb. You can get these from Amazon.com Part Number : BS-142P6
I've looked everywhere and they are TOUGH to find. Unfortunately, I bought the wrong thread size initially from McMaster/Carr. I just had my dad machine them down to 1/4-20. I will tell you ... McMaster-Carr does not sell these in 10mm- 1/4-20... (I checked)
You will use the existing holes so there is NOTHING to drill or tap. On the door you use the only hole on the top of the door and on the top of the door frame (underside of the interior roof), you will use the holes CLOSEST to the center on both sides. Tighten the ball studs until they are seated flush.
an action shot of my mad ratchetin' skills
STEP 3: Install the gas struts. I used MONROE Part # 901460 Universal Lift Support; 23 Actual Ctr. To Ctr. Extended Length; 40 lbs. Force; This is a UNIVERSAL lift support which will save you a TON of cash. The 40 lbs wont spring the door open when you pop them open, but it is MORE than enough to open it.
They literally pop right on. I read somewhere that you need to have the skinny part of the strut (or shaft) near the bottom, so the larger part (housing) can lube it everytime it opens and closes.
VIDEO
http://s213.photobucket.com/albums/c...t=25506ea0.mp4
STEP 4: Your done. Have a beer and kiss those sliding mechanisms "GOODBYE!"
RockAuto.com
MONROE Part # 901460 Universal Lift Support; 23 Actual Ctr. To Ctr. Extended Length; 40 lbs. Force; Universal Lift Support
2 of these:
Price $13.48 x2 = 26.96
Amazon.com
10MM Ball Stud with 1/4-20 threads for Gas Spring/Prop/Strut (6 Pack)
by API
You need 4, but they come in a pack of 6
Price: $10.75
Total price for this project 37.71+ shipping
by they way... does anyone need a set of these, because I am DONE with 'em.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 02-08-2012, 08:40 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: So... do you want gas struts on your barn doors?
Great write up Jeff...it's about time you got that done.....hope that beer was nice and refreshing
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-08-2012, 09:26 PM   #3
jeffg1010
jeffg1010's Avatar
I should've have done it MONTHS ago. It's one of the top 5 "practical" things I have done to it.
I have 4 more gas struts if you want to try them. I had a couple gift certificates for Rock Auto, so I bought 6. I figured 2 for the Burb, 2 for the Blazer and 2 for dads Burb. In Hart Rod's clam shell gas strut conversion thread, he noted the heavier metal liftgate needed a bit more strength to lift his gate. He used struts from a Volvo I think. But when you get vehicle specific struts, they are about double in price. These are universal, so they are cheap. If you get the studs from Amazon, you can try these to see if they will work for you.
and yep, the beer was good. While I didn't have to work real hard (at all) to get it, it was a sigh of relief to get rid of those stupid slides. They are a pain in the rear, they are dangerous, and I am lucky I havent busted a taillight with them.
BY THE WAY... for anyone reading this thread that is considering doing the same thing to a liftgate/tailgate combo. That thread exists too...
http://67-72chevytrucks.com/vboard/s...d.php?t=220511
thanks to Hart Rod...
Jeff
Old 02-08-2012, 11:19 PM   #4
Average Joe
Average Joe's Avatar
Thank you!!!!!!!!! I too hate my factory mechanisms. Great write up. Looks so easy an Average Joe could pull this off. This deserves a spot in FAQ.
Average Joe is offline   Reply With Quote
Old 02-08-2012, 11:32 PM   #5
jeffg1010
jeffg1010's Avatar
Thanks! Sad thing is, it took me longer to upload photos and type it out than it did to complete the job. However, as an update... I found that by repeating step 4 a couple times, the project became more fulfilling. haha.
Jeff
Old 02-09-2012, 03:07 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Those MonroeMax Lift Struts will last as long as you own your Burb. I put a set on my 94 Burb tailgate glass last Winter and they work perfectly ,even in -30 degree weather which we get up here.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-09-2012, 09:43 AM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Yep....I'll take them....what do I owe ya....I have beer!!! Maybe you could come down and help or I'll come to your place....
FYI...I'm going to try and get some studs from a 68 truck fuel pedal like Hart_Rod used....we should see if they work on your barn door application too so others will know!!!
Geoff with a G
Old 02-09-2012, 09:43 AM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
I already recommended it
Geoff with a G
Old 02-10-2012, 08:28 PM   #9
Street Smart
Street Smart's Avatar
I found these, it should do the trick.
http://www.sears.com/shc/s/p_10153_1...1&blockType=G1
http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 02-10-2012, 08:39 PM   #10
jeffg1010
jeffg1010's Avatar
Originally Posted by Street Smart View Post
I found these, seem pricey for what your getting, but it should do the trick.
It's good to know there are other options out there, but those are a lot more expensive than the one's on Amazon.
Anytime. Let me know if you find the studs. I know Hart Rod used the '68 pedal studs. My burb isnt exactly the "poster child" for the OEM truck crowd, haha
-30?!?!? Our all-time record low here is 0. haha
Jeff
Old 02-10-2012, 08:40 PM   #11
YBNORML
YBNORML's Avatar
Great write-up, Thanks. I have been thinking about doing this with my Blazer.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-10-2012, 08:47 PM   #12
jeffg1010
jeffg1010's Avatar
My Blazer is next. I've got the struts, just gotta get more ball studs.
Jeff
Old 02-11-2012, 01:11 AM   #13
CG
BlahBlahBlah
Nice job. A lot of guys are going to benefit from this, including me!
Old 02-11-2012, 08:35 PM   #14
Street Smart
x2
Old 02-11-2012, 08:43 PM   #15
Newtz67
Newtz67's Avatar
Wasn't sure till I saw the budlight...
Newtz67 is offline   Reply With Quote
Old 02-12-2012, 07:47 AM   #16
72 DIRTY RAT
72 DIRTY RAT's Avatar
good job! I think I will do the same.
*1972 454ci Burb, C20 3/4T, T700, 2WD
*1969 540ci Vette, 540ci Aluminum BB,755 BHP & 734 LbFt torque, No NOS, No Forced induction! Just BIG CUBES
72 DIRTY RAT is offline   Reply With Quote
Old 02-12-2012, 11:57 AM   #17
LockDoc
The Older Generation
LockDoc's Avatar
I found these ball studs. Package of 6. Shipping came up at $4.99 for me.
http://api-llc.amazonwebstore.com/10...ffId=the005-20
LockDoc
Leon
Old 02-12-2012, 12:09 PM   #18
jeffg1010
jeffg1010's Avatar
LockDoc
Yeah, those are the same ones I recommended in step #2. I am anxious to see a few more guys do this.
Jeff
Old 02-17-2012, 03:29 PM   #19
augie
Waiting for Paul to Open Safe
augie's Avatar
Thanks for the great info Jeff. It's now a FAQ and can be found here: http://67-72chevytrucks.com/vboard/s...d.php?t=509544
Norwood Survivor
http://squarebody.net
augie is offline   Reply With Quote
Old 02-18-2012, 05:21 PM   #20
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I am working on it, got the studs in this week.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-22-2012, 10:59 AM   #21
jeffg1010
jeffg1010's Avatar
WOW! I am now immortalized in the FAQ's
Smitty
Once you get the struts, dont put it off like I did. They sat in the garage for three weeks. Once I got ready to do it, and got a few tools together, it took 15 minutes. And I thought... WHY DID I PUT THIS OFF?
Jeff
Old 02-24-2012, 09:41 PM   #22
71meangreenc10
Rockauto dropped off the struts today, went in super fast.
Great mod Jeff....
Smitty
71 C30 Wrecker
Old 02-24-2012, 10:41 PM   #23
rsavage
rsavage's Avatar
Nice job and write-up. You have shown me another way to spend more money, but at least it is an inexpensive project.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-01-2012, 01:38 PM   #24
BennettGM
BennettGM's Avatar
I like that a lot! So how would these gas shocks work on the lift glass of a 72 Suburban? That thing is heavy!
BennettGM is offline   Reply With Quote
Old 03-01-2012, 01:43 PM   #25
gcburdic
Restoration Virgin!
gcburdic's Avatar
Go here and review this thread for lift gates
Geoff with a G
