Old 01-18-2022, 10:13 PM   #426
jimbosprint
jimbosprint's Avatar
Re: '72 Cheyenne K10
I replaced the windshield washer pump today. What a weird mechanical contraption driven off the wiper motor.
jimbosprint is offline   Reply With Quote
Old 01-19-2022, 12:38 AM   #427
jimbosprint
I got a new pen tablet so I sketched a picture of my truck tonight.
Old 01-19-2022, 09:00 AM   #428
Jiggers72-GMC
Jiggers72-GMC's Avatar
Nice job on the sketch and the ww motor, looks good
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 01-19-2022, 09:59 AM   #429
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
X2, I have never tried a washer pump or a sketch. I don't think my sketch would be recognizable.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-19-2022, 10:09 AM   #430
landarts
landarts
Great looking sketch of your truck Jim, it has the 70's vibe look going on. Great work on the truck as always.
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
69 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 01-19-2022, 09:39 PM   #431
jimbosprint
Thanks guys. Today I got the steering column back into the truck. I had to cut the connector off the new turn signal switch and change it to the connector for the AAW harness. I'm proud of my terminal ends which are usually a pain. I had to take the brakes off the firewall again to get the steering column gasket to fit. Then the brake pedal grommet would not seat on the firewall so I had to take the brakes off another time! A lesson was learned - bolt the Hydroboost to the bracket before putting both on the firewall as one unit.
Old 01-19-2022, 09:40 PM   #432
jimbosprint
I also put the cowl back on with a cowl debris screen and a new hood seal.
Old 01-20-2022, 12:21 AM   #433
rickcdewitt
rickcdewitt's Avatar
Lift height and tire size looks good.tuff country 2" front and 3"+1" rear with 33s correct?
Looking forward to seeing how the hydroboost works out.
Just read the whole thread. Now i want to dust off my build thread and get some work done on it!
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
Old 01-20-2022, 08:21 PM   #434
jimbosprint
Thanks, rickcdewitt. That is the correct lift/tire combo.
Old 01-20-2022, 08:32 PM   #435
jimbosprint
Today was a day of frustrating setbacks.
I started bleeding the power steering fluid, and my pedal adapter bent in half right away. I guess there is a lot more leverage on that brake pedal than I thought. The money spent on it was all wasted, and I refunded the money for the one that I sold. I need a new plan for pedal linkage.
Discouraged by the brakes, I figured I would get the steering wheel back on and the horn working. I assembled the horn parts, but still no working horn. So I checked under the hood and found power at the horn all the time. So I checked the horn relay and found it was super hot to the touch! I assume that my horn is bad since it does not work with power. But I do not know why the relay sends power to the horn all the time even without the horn button assembled.
Also, my new turn signal cancel cam does not work both directions even with the new turn signal switch. I cannot figure it out.
Old 01-20-2022, 10:33 PM   #436
jimbosprint
Unplugging the column turns off the horn relay (and thus power to the horn under the hood). Maybe I damaged and grounded the horn wire while assembling the column? I suppose I will have to take it apart to find out.
Old 01-21-2022, 07:53 AM   #437
Jiggers72-GMC
Sorry to hear all that Jim, we've all had days like that, you'll figure it out,
when I run in to a problem, I usually find the answer in this forum, good luck.
is it possible that your horn button is stuck down .....
Old 01-21-2022, 10:17 AM   #438
Ol Blue K20
X2 on check the horn button. I've had problems with the flat round spring grounding all the time. I thought you're adapter looked good. Back to the drawing board. You'll figure it out, I have faith in you..
Dale
Old 01-21-2022, 03:02 PM   #439
jimbosprint
Couldn't sleep last night - colored in my truck drawing.
Old 01-21-2022, 04:50 PM   #440
Ol Blue K20
Nice.
Dale
Old 01-23-2022, 01:59 PM   #441
rowdy11
Sorry to hear about the pedal adapter. I've been thinking about the same issue lately and your experience, while painful, is getting me to think about much thicker stock to use. Keep at it!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 01-23-2022, 09:26 PM   #442
jimbosprint
I decided to just give up on making a bolt-on pedal adapter. I cut the end of the Hydroboost pushrod off and threaded it 3/8"-24. Pedal linkage solved.
I also took apart the steering column to find the wiring short. It turns out the horn contact on the signal switch was touching the signal support casting. I filed off the extra metal and now the horn isn't getting constant power. I wrapped all the wiring in some tape to better protect it.
Old 01-24-2022, 09:33 AM   #443
Jiggers72-GMC
Well done Jim, looks like you got it this time.
Old 01-24-2022, 10:18 AM   #444
Ol Blue K20
I'm glad you got the problems sorted out. Nice job.
Dale
Old 01-27-2022, 01:43 AM   #445
rickcdewitt
Why did you use the astrovan booster?
Has anyone used one of these?
https://westernchassis.com/1967-72-C...ke-Assist-Kit/
Old 01-27-2022, 04:55 PM   #446
jimbosprint
I am fairly sure the Astrovan booster is the same as the one in that kit.
Old 01-27-2022, 05:02 PM   #447
jimbosprint
I got to take the steering wheel off again because the turn signal arm fell off. The previous owner had it held on with the wrong screw. Fixed.
Old 01-27-2022, 08:16 PM   #448
jimbosprint
After what seemed like a thousand turns lock to lock and plenty of wasted ATF puking out of the pump, I think the power steering fluid is bled. I didn't crash during a short test drive around the block. The brakes are much more responsive. I don't know what it is supposed to feel like, but it functions. I will be driving cautiously and watching the steering fluid level closely.
Old 01-28-2022, 07:58 AM   #449
Ol Blue K20
Probably the price would be a reason for me.
Dale
Old 01-28-2022, 08:00 AM   #450
Ol Blue K20
Good job, be easy on it and stay safe. It's nice to hear that it's more responsive!
Dale
ochre
