Old 08-16-2014, 02:39 PM   #1
Dave67
Junior Member
Dave67's Avatar
Question HELP! Gas tank vent
With my tail light filler, I can't run a vented cap. I bought a small tank vent for a motorcycle, but I notice I can blow air both ways through it. Shouldn't it block air form one direction? I figure it should let air in the tank, but block gas from spilling out. What am I missing?
67 C-20 LWB
56 Nomad--- nope, sold it
75 Stingray
13 Silverado crew cab
08 Trailblazer (wife's)
Pittsburgh, PA
Dave67 is offline   Reply With Quote
Old 08-17-2014, 02:41 PM   #2
Dave67
Junior Member
Dave67's Avatar
Re: HELP! Gas tank vent
Ttt
67 C-20 LWB
75 Stingray
Pittsburgh, PA
Old 08-18-2014, 07:52 PM   #3
luvbowties
luvbowties's Avatar
Smile Re: HELP! Gas tank vent
I think u put a vent on your ride. What u describe later is a valve?
s
luvbowties is offline   Reply With Quote
Old 08-18-2014, 08:12 PM   #4
luvbowties
luvbowties's Avatar
We just finished putting a Northstar in a '48 Cadillac. Drilled a hole in tank near sender-opening--where we could tighten jamb nut from inside tank--used a fitting from Lowe's for a tank: water? air? I dunno, just looked like what we needed. Ran a fuel hose from fitting up high into wheel well, & fastened a plastic, see-thru filter(about 2" in diam.) into end of hose & secured to inner fender. Filter must've been for a big truck/tractor, going by size of opening. Try to run a 1/2-inch fitting/hose, at least. Really think ours was bigger than 1/2!
hth,
sam
Old 08-18-2014, 09:53 PM   #5
Dave67
Junior Member
Dave67's Avatar
thanks!
I just ordered an actual check valve to put on the tank. Otherwise my set up is like yours. I figured out a one-way check valve will solve the problem.
67 C-20 LWB
75 Stingray
Pittsburgh, PA
Old 08-18-2014, 10:45 PM   #6
luvbowties
luvbowties's Avatar
Glad u found what u need. Luck with your project. An added under-the-back gas tank can be a bear to remove/replace. Ask me how I know.
Will yours have a true vent AND this 1-way check valve too? Curious as to what type fuel/intake system u got--EFI or CARB?
One more thing: if u don't mind revealing: exactly what 1-way valve are u getting? I'd like to know, as I've studied a bit on EFI and various pump systems and am always wanting to know more. I actually do more helping friends & acquaintances w/ideas & theory[plus some hands-on] than actual start-to-finish projects by myself. Thanks.
Sam
Old 08-19-2014, 07:43 AM   #7
Dave67
Junior Member
Dave67's Avatar
This is the check valve I'm planning to use. I hope You can see it, because I'm not sure how to post a pic. I'm just running a Regular carb, and everything was working fine, with my vent tube running up inside the bed. The only problem was when I topped off the tank, I'd have a little bit of fuel spilling out the vent tube. I'm guessing the check valve will eliminate that.
67 C-20 LWB
75 Stingray
Pittsburgh, PA
Old 08-19-2014, 07:49 AM   #8
Dave67
Junior Member
Dave67's Avatar
Ok, this might work
67 C-20 LWB
75 Stingray
Pittsburgh, PA
Old 08-19-2014, 10:45 PM   #9
luvbowties
luvbowties's Avatar
Thx, Dave for the pic--it helped me visualize how it looks and works. Hoping it will stop that spill during fillup. Many options to cure same problem, and one cannot know too many!
Sam
Re: showing pics on forum: save pic, like in jpeg form, on desktop(easy to find there when named with easily-remembered name )>click "manage attachments" below bottom of message-composing box>click on "browse">navigate to "desktop" thru "browse">select the pic u saved on desktop>click "open">click on "upload"!! you're done. If I missed or mis-named a step, please use intuition to correct my error, as I believe I'm close enough.
*PS: however u did it, it showed up very well. Again, maybe another solution to one project!
Old 08-20-2014, 07:25 AM   #10
Dave67
Junior Member
Dave67's Avatar
Sam, thanks for all your help!
67 C-20 LWB
75 Stingray
Pittsburgh, PA
Old 08-20-2014, 08:58 AM   #11
no1udknow
no1udknow's Avatar
hth,
sam
I would agree with this with one exception,run the hose upward, put the filter/check valve at the highest point and aim the end of the hose downward as not to hold any moisture/dirt etc or cap the end with a differential breather, something to keep dirt and bugs out of your tank. They like to crawl in to the damned'est places.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 08-20-2014, 09:37 AM   #12
Dave67
Junior Member
Dave67's Avatar
good call
67 C-20 LWB
75 Stingray
Pittsburgh, PA
