09-16-2021, 12:17 PM | #1 |
C10/C20 Body Differences
I have a '62 C20 that I have pretty much had to replace Fenders, grill support, and radiator support with aftermarket items due to rust or other damage. Trying to do a dry fit right now and the holes just aren't lining up. Some more than an inch off......AM I missing something here? There's nothing I have found when going back and looking at what I ordered compared to the options available that had a different part number for a C10 over a C20.
09-16-2021, 03:05 PM | #2 |
Re: C10/C20 Body Differences
It could be the aftermarket components themselves.
How's your cab mounts and core support mounts? If those are missing or blown out, you'll have a hard time getting everything lined up too
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-16-2021, 03:08 PM | #3 |
Thankfully Cab and Core Support Mounts are in perfect condition. Thinking I just have to make it work. Not a big deal, just way more work than I hoped.
09-16-2021, 03:10 PM | #4 |
Yup, that's the unfortunate part of the full aftermarket parts.
A tip is don't tighten any bolts completely until you have every bolt in its home on all the panels. Then you can go back and tighten them all up
