02-09-2023, 08:00 PM | #1 |
NP205 Stick Pivot Bolt. You Must Be Kidding…
$90-$100!? If they have it. Which they don’t. Any realistic alternatives?
I was going to use the adapter from a ‘72 on my ‘70 burb because one of the bolt holes on the bottom for the mounting bolts was stripped. I’d run a long bolt all the way thru that hole and put a nut on the other side. Worked, kind of tacky. Oh well, I may just have to be tacky because I doubt I can pay $100 for a bolt. If I can find it… |
02-09-2023, 08:41 PM | #2 |
Re: NP205 Stick Pivot Bolt. You Must Be Kidding…
I won't promise it'll fit but this looks to be a lot less money.
https://jb-custom-fabrication.myshop...lt-upgrade-kit |
02-09-2023, 09:34 PM | #3 | |
Cost you postage is all. Or? https://www.ebay.com/itm/35449413967...Bk9SR-jXuo_HYQ Cheers. |
02-10-2023, 01:23 PM | #4 |
All about them K’s
My local machine shop is able to make them. Might look into that route if you are wanting new. You could always pay to subscribe and post a want to buy here on the classifieds board. They come up for sale semi frequently there.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
02-10-2023, 02:30 PM | #5 |
I am currently using the JB bolt, it's a 9/16 on the threads, plus I had to use my own bushings. I use an aluminum advance adapters aftermarket transfer case adapter so the threads were larger than my stock cast iron adapter, it had 7/16(I'm pretty sure) Check the threads. I also have and non bushing bolt with a 9/16, but I like the bronze bushings better, it has a smooth action.
But, if Accelo makes one for you that the best answer/solution. j
White K20 |
02-11-2023, 09:46 AM | #6 |
Where did you see the bolt for $90-$100?
02-11-2023, 09:20 PM | #7 |
Anybody that has the original new GM bolt, part #14009313, wants about $100 for it. Looks like it’s been discontinued. That’s the greasable one.
Thanks for the responses. I just ended up welding a new head on the old one I had. Took too long, probably should have spent the money. If anybody is interested, sbc valve spring shims are perfect for washers to take up any slack. |
03-06-2023, 12:50 AM | #8 |
I made one, based on one I had here, that may or may not be correct.
Here is a picture, the threads are 1/2" NC. Somehow I don't think that correct. If it will works for someone it's $30 includes shipping. I can drill it for the grease fitting if that's important. Last edited by Accelo; 03-26-2023 at 01:59 PM. |
