Old 02-23-2012, 02:53 PM   #1
closer9
School me on driveshafts?
While changing wheel bearings, found my front driveshaft has a lot of play in the slip joint. Had noticed a slight vibe on the highway, now I know why. Will any square body front shaft fit? I have a 203 case. Figure someone around here will have one for sale, but want to know what I'm looking for first. All else, I'll take mine to a shop...
79 K5
Thanks...
closer9 is offline   Reply With Quote
Old 02-24-2012, 04:17 AM   #2
rcbildr
rcbildr's Avatar
Re: School me on driveshafts?
No, you will have to find a truck with the same trans and t-case set up because they are different lenghts depending on what transmission and transfer case is in the truck. IIRC there are also two different ways the d-shaft bolts to the transfer case too. I believe yours uses small u-bolts that secure the u-joint to the yolk of the t-case and the newer (whenever they started using the NP-208 I think) uses a flange with 4 bolts.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-24-2012, 05:18 AM   #3
tobiahr
tobiahr's Avatar
when i owned a 4wd i found it was usually easier and cheaper to find a driveshaft shop and have them build one. i would go through a couple of junkyard ones before i would find the perfect one but got the perfect one the first time from a shop.
tobiahr is offline   Reply With Quote
Old 02-24-2012, 11:59 AM   #4
closer9
Thanks, that's what I figured, but wasn't sure. I'll look around a bit, but will probably end up at a shop.
