Old 01-16-2022, 12:39 PM   #51
Day 2 C10
Re: The Wrong Bed C10 build
Originally Posted by 69newguy06 View Post
What did it actually make on the dyno? Come on man, you can't say it's going and not post numbers.
I have every intention of posting numbers both of the engine and at the rear wheels. The engineers at work have to find time to squeeze it in between r&d engines to run personal projects. Once it’s run and the truck is back together I’ll squeeze it in on the chassis dyno schedule between R&D and Beta cars. It’s a great perk of my day job but I have to be at their mercy for convenience. FYI I’m basing my prediction on previous builds and our programs at work and until done is a hypothetical.
Day 2 C10 is offline   Reply With Quote
Old 01-16-2022, 12:44 PM   #52
Day 2 C10
Tied up a bunch of lose ends yesterday before turning the truck around today and starting on the rear. Most notably was the body mounts as they were original! Also got the 1/2 fuel system 100% done and added some hush mat between the tank and the cab.
Old 01-17-2022, 02:03 PM   #53
Day 2 C10
Got the ol' wrong bed out of the shop in spun around in the drive way to back it in.(FYI don't try to do this on black ice.) But now its pushed back in and time to start on the rear drop tonight.
Old 01-17-2022, 10:46 PM   #54
Day 2 C10
Not a major night tonight took it off to get the latest round of salt off my dually before this weeks cold snap. I did get to put my old 1964 Ajax high lift to use as a way of stabilizing the truck on the stands.
Old 01-17-2022, 11:34 PM   #55
golfandcars
Dang i wish i had one of those jack thingys lol would have saved me banging my head 3 different times in the last week.
golfandcars is offline   Reply With Quote
Old 01-18-2022, 11:59 PM   #56
Day 2 C10
Got the rear end taken out tonight and still have to deal with some seized hardware.
Old 01-19-2022, 12:20 PM   #57
Love the look of your truck. I am curious, what size tire do you have on the rear. It looks very beefy.
Palf70Step is online now   Reply With Quote
Old 01-19-2022, 01:43 PM   #58
Day 2 C10
Thanks I’m running 33x12.5 15s on 10” mags
Old 01-20-2022, 01:50 PM   #59
Day 2 C10
After a night of slogging through rusted hardware finally got almost the old parts off and broken down. I still have one more trailing arm mount to remove. (as you all know the rivets suck) Still have to figure out if I'm going to just flip the brackets or get the adjustable ones.
Old 01-25-2022, 03:46 AM   #60
Low Elco
Progress!
Low Elco is offline   Reply With Quote
Old 01-26-2022, 02:11 PM   #61
Day 2 C10
So no post for a short bit because I went like a mad man and banged out the rear half of the truck last weekend. Stripped and painted the frame and rear rails and redid the arms and rearend. Flipped the front mounts new hardware and polyurethane and air shocks it should ride pretty good. I welded on the new panhard mt and still waiting on my finned diff cover and shorter bar. But I settled at a 4" drop in the back and with it, it'll maintain its hot rod 60/70s rake and stance. Still got some lose ends to tie up like fabbing a new hitch but its coming together.
Old 01-26-2022, 02:12 PM   #62
Day 2 C10
some more
Old 01-26-2022, 02:13 PM   #63
Day 2 C10
last group and those are 33x12.5 -15
Old 01-28-2022, 02:11 PM   #64
Day 2 C10
New diff-cover showed up so I gave it a mag finish to finish off the rear-end just waiting on the right length panhard bar now plumbing the axle tonight.
Old 01-30-2022, 12:36 AM   #65
Day 2 C10
Rear chassis is 100% done took the opportunity with the good weather to roll the truck outside and view the new stance. Hopefully I can get a shot at the company dyno in the next couple of weeks so the motor can go in. In the meantime I’ll tie up some stuff starting with Fabing up a new hitch
Old 01-30-2022, 12:50 AM   #66
Day 2 C10
A couple more
Old 02-05-2022, 04:40 PM   #67
Day 2 C10
After being sick for a bit. Fab’d up a new low profile hitch for so I can drag around some of my race cars.
Old 02-06-2022, 03:50 PM   #68
CG
BlahBlahBlah
What did you used to put the magnesium finish on the rear diff cover? It looks great.
Old 02-06-2022, 03:58 PM   #69
Day 2 C10
Thanks, I started with engine cast iron gray then dusted it with gold metallic before satin clear after which I oiled it with wd40.
Old 02-18-2022, 02:40 PM   #70
Day 2 C10
Squeezed the engine onto the work dyno after hours. Little 355 made 469 hp @6700 and 413 ft lbs @ 5200 . Got it home and wasted no time dropping it in the truck. Waiting on the clutch to show up this weekend and hopefully getting it all buttoned up in the next few days. made a lunch time run to LMC for peddles and some other lose end(great to work around the corner. Pics are from before and after dyno (didn't want to be that guy in front of the other guys from work) but supper happy with the progression.
Old 02-18-2022, 02:45 PM   #71
Day 2 C10
A few more.
Old 02-22-2022, 06:44 PM   #72
Day 2 C10
Got the hood back on and picked up the remaining mandrel tubes at work to fab the exhaust. It was nice to be able to get the truck outside in to the world and step back I adjusted the rear down 2" after the photos. The dogs are excited for spring!
Old 02-22-2022, 06:54 PM   #73
Day 2 C10
A before and after of the drop to show the 4.5/4 inch stance
Old 02-22-2022, 07:53 PM   #74
SCOTI
SCOTI's Avatar
Lookin slick!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-22-2022, 08:07 PM   #75
KevinK7
KevinK7's Avatar
Truck looks GREAT!
That stance is perfect ; )
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
