03-27-2017, 06:02 PM | #1 |
1987 Chevy Truck heater hose
Hello, my 87 Chevy heater hose has a rust spot in the metal part blowing antifreeze out. Went to fix but the 1in nut that is connected to metal I'm not able to reach and get a wrench in there to loosen so I can replace the hose. Any suggestions of what I need to do? Can't afford to have a mechanic fix. Thanks
03-27-2017, 07:24 PM | #2 |
Robert Olson Transport
Re: 1987 Chevy Truck heater hose
can you post a picture of it?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
03-29-2017, 09:32 AM | #3 |
We are asking because there are no nuts on normal heater hose set ups. Everything is clamps, and the 'correct' ones I have worked on have no pipes inline, only connections at the water pump / manifold and heater core. With A/C there might be a Ranko vacuum actuated valve in the hose. So a picture of your issue area would be helpful.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
03-29-2017, 09:57 AM | #4 |
I will get a picture soon, been working late hours, the metal hose is connected to the intake
03-29-2017, 10:10 AM | #5 |
When you say "metal hose" are you referring to the water neck that attaches to the intake and the hose to the radiator?
03-29-2017, 10:38 AM | #6 |
Yes, I'm having trouble loading a pic.
03-30-2017, 12:32 PM | #7 |
The Tbi trucks did have a hard line crimped on the end of the hose. I have cut them off and used a socket to take off. I agree they are difficult. I'll see if I can find a pic
-Cody |
03-30-2017, 12:38 PM | #8 |
http://67-72chevytrucks.com/vboard/s...ad.php?t=83905
I'll see if link works. Once it's out you can replace with a regular nipple.
-Cody |
03-30-2017, 12:45 PM | #9 |
Most all of the Tbi engines had them, s-10, full size. Back of the intake on the passenger side
-Cody |
01-19-2022, 03:11 PM | #10 |
Sorry for bumping an old thread, but I just replaced the heater core on my 87 Jimmy and want to update the hoses while I'm at it. Does anyone sell the OEM heater hose with the metal on the end? I don't want to take a chance on breaking the fitting off or messing up the intake by trying to remove the fitting. Thanks in advance.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-20-2022, 05:26 AM | #11 |
The pic on the left I think most people thought you had. because you did not say you had or were working on A/C heart core. Well that second pic looks like a A/c line to the condenser in front of the rad ( like another rad to cool A/c oil/gas liquid mix) I guessing you have the big heater case cover on the fire wall for A/C option. If the line from vapor to the condenser is what your looking for 87 try the Dealer may have them still, or your auto parts store, E-bay, scrap yard. If you go with good used lines make sure you get new a/c O-rings for the fittings.
This is a pic of a A/c heater core case Picture On the right.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 01-20-2022 at 05:32 AM. |
01-20-2022, 06:06 AM | #12 |
Just here to tinker
He’s talking about the coolant hose on the TBI engine, not the ac lines.
-Just take a socket and remove the fitting in the intake. Use a 6 point socket, an impact and PB blaster so you don’t round it off. When that’s out, you can get a barb to NPT adapter and put a regular hose and clamp on it.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
01-20-2022, 11:28 AM | #13 | |
01-20-2022, 12:32 PM | #14 |
I would take the hose into Napa or someone who makes pressure hoses and see if they can make you up the hose or at least a fitting end for the core side that a heater hose can be pushed onto then a clamp.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
01-20-2022, 01:42 PM | #15 | |
If it's bad enough to break then it needs to come out.
01-21-2022, 09:31 PM | #16 |
those fittings rot so its good to take them out and replace them. you can do it now or have it towed when It breaks off somewhere on the side of the road.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
01-22-2022, 06:45 AM | #17 |
