10-09-2021, 11:06 PM | #1 |
Old bed wood needed
The wood in my '55 long bed is mostly good, I'd like to keep it. There are two or three boards that should be replaced but I don't want new wood. I'm in Oregon but driving to Mesa Az for the winter and could stop on the way if anyone wants to sell me a few used slats. Thanks, Bob
10-10-2021, 01:46 AM | #2 |
Re: Old bed wood needed
You can probably find some old straight grain yellow pine boards that have the proper aging that you can just trim and cut the grooves for the strips and by spring they will look like the rest of the wood in the bed.
10-10-2021, 09:37 AM | #3 |
I'm sure, around your parts, there are lots of old barns where you could get a few pieces.
10-10-2021, 07:34 PM | #4 |
You can artificially age new wood with a mix of vinegar and steel wool. Let 00 steel wool dissolve in vinegar a couple of days, then wipe on the wood. Let it sit overnight to see how dark it is before adding any more, then repeat as necessary to achieve a close match.
1951 Chevy Panel Truck |
10-10-2021, 09:18 PM | #5 |
Now that IS GOOD ADVICE! I'l give the aging process a try, thanks.
10-18-2021, 12:26 PM | #6 |
sand blasting will make new wood old fast
combined with vinegar & steel wool might be what you want
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-19-2021, 03:19 AM | #7 |
10-19-2021, 09:31 AM | #8 | |
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
