11-28-2022, 07:19 PM | #1 |
Gas gauge to 90 ohms
With the installation of a Camaro tank and the 90-ohm sender, it seems that the quickest solution to convert the 30-ohm gauge is a 90-ohm resistor.
Pic 1: 1966 warning cluster gauge gas gauge (not mine) Pic 2: the 90-ohm resistor Plan: Remove the 30-ohm shunt and harness tangs, add the 90-ohm shunt and plug the harness back in. I may add an additional ground. Thoughts? |
11-28-2022, 07:45 PM | #2 |
Moderator
Re: Gas gauge to 90 ohms
Can't wait to see if it works.
11-29-2022, 05:38 PM | #3 |
Call John at Redling Gauge Repair. He can tell you how to make it work. 731-571-0766
https://www.redlineg.com/contact He changed my AMP Gauge into a Volt Meter and also calibrated my Temp Sending Unit to my Temp Gauge. Good Luck |
11-30-2022, 07:46 AM | #4 |
Moderator
Run some test leads to/from the sender, it'd be easy to find out.
11-30-2022, 11:04 AM | #5 |
You might want to look at this wright up.
http://67-72chevytrucks.com/vboard/s...d.php?t=447185 |
11-30-2022, 11:12 AM | #6 |
