08-21-2008, 12:45 AM | #1 |
Van tilt columns
These things are all over ebay for cheaper than real truck ones. My question is how do you get the thing to bolt up to the steering box? I know that the output shaft on the bottom of a van tilt is bigger than on a truck, so what are you supposed to put on the bottom of these to make them bolt up?
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
08-21-2008, 01:14 AM | #2 |
Trucks N Tranzams
Re: Van tilt columns
Check out these links to the truck tech FAQ. They will show you the way.
http://67-72chevytrucks.com/vboard/s....php?p=1818810 http://67-72chevytrucks.com/vboard/s...d.php?t=133937 http://67-72chevytrucks.com/vboard/s...d.php?t=302488
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
08-21-2008, 07:29 AM | #3 |
Easy install.......
1997 GMC Sierra Ext 1965 Mustang |
08-21-2008, 11:08 AM | #4 |
its all about the +6 inches
I've installed a bunch of these... never had an issue with size.
Shorten the intermidiate shaft... that's the only real mod needed. |
08-21-2008, 12:35 PM | #5 |
Mike
I am getting ready to pull the van tilt in my suburban out to do some work on it. The head is sloppy and has quite a bit of movement. For any one interested here is a link to the van tilt manual.
HTML Code:
http://www.selectric.org/manuals/column/index.html
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
08-22-2008, 09:04 AM | #6 |
Shorten intermediate shaft, reposition the neutral safety switch, purchase a harness conversion, replace the turn-tilt levers, the hazard button and the shift lever and no one will know the difference from the cab!
08-22-2008, 09:37 AM | #7 |
I just picked up a van tilt on Screwbay For $100. I just realized that it was sold w/o the intermediate shaft? Can I use the intermediate shaft from my non tilt column. BTW, some of the the links used to describe the wiring and neutral safety relocate are no longer valid. I could not fond anything in the FAQ section... Another BTW, I go tan email that after Oct., Screwbay will no longer allow money orders or personal chacks as payment. Electronic payment only. Just a coincidence that they own Paypal now?
08-22-2008, 10:12 AM | #8 |
I was scouring the local yards the last few weeks in search of the ever elusive VAN tilt with key on the dash. I have come across ALOT of the later model vans with the key on the column.Has anyone here transplanted one of these into a 67-72 truck? I was thinking if someone was going to go custom anyway, why not add some security by adding a locking column to your truck and filling the old keyhole in the dash?
08-23-2008, 03:00 AM | #9 | |
and in the article I noticed they used an intermedate shaft from a 73-87 truck which answered that question for me. I to would like to know about the neutral safty switch modification, I hadn't heard of it before.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made Last edited by sweet70beast; 08-23-2008 at 03:01 AM. |
08-23-2008, 08:09 AM | #10 |
Early Chev van tilt columns are longer & the placement of their neutral safety switch binds off on the column support bracing on a truck thus you need to reposition this switch. Cut outer column with dremel -weld in a little tab--and re attach for clearnace.
The intermediate shaft is virtually identical between tilt and not tilt but you will need to shorten it for a van tilt. Drill out 2 plastic plugs (sand flat area of shaft to find them) then shorten the shaft by pressing it together. Most van tilts have a flat connector for the wiring harness while trucks have a 1/2 moon connector. GM offers a conversion harness for this for about $12. Van tilts typically sell for $100-200. while original truck tilts go for $250.-350. It takes about an hour to convert a van tilt to work identical to a truck tilt. Most Van columns have a smaller steering wheel, rubber tipped levers, and many have cruse turn signal levers which can be wired into a theft diterrent (ie push the button for start!) Huck |
10-21-2008, 08:45 PM | #11 | |
bringing this one back up
BTW I must have gotten an earlier one, cause it has the half moon connector....scored it for $75 at the bone yard. |
01-31-2023, 11:47 AM | #12 |
What spline count are the van columns? that never seems to get mentioned & for me it would be helpful.
01-31-2023, 03:49 PM | #13 |
I recently had board member 70shortfleet convert a 70's automatic van tilt to manual for my 66 K10 Suburban. He does outstanding work and can customize them any way you like. I cut the original manual steering shaft to desired length, then used a Borg steering coupler (welded to original steering shaft) to join the two together. I have found that in most cases, the spline on the van tilts is 3/4 in. 36-Spline.
https://www.summitracing.com/parts/BRG-313400
66 GMC Suburban Custom 66 Chevy K10 Suburban |
