Old 06-24-2009, 02:39 PM   #1
JW76
JW76's Avatar
12 bolt axle
Are the perches on a 69 axle in the same spot for both trailing arms suspension and leaf spring. Also, are they the same size? Thanks for any help.
JW76 is offline   Reply With Quote
Old 06-24-2009, 03:38 PM   #2
silvereagle07
silvereagle07's Avatar
Re: 12 bolt axle
The width it the same but the spring perches are different I think.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-24-2009, 09:38 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 12 bolt axle
They are very different. The coil spring perches are angled.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-26-2009, 02:35 PM   #4
Kontrol Phreaks
Kontrol Phreaks's Avatar
Re: 12 bolt axle
The perches are differnt as the trailing arm trucks have angle perches, and the leaf spring trucks have straight perches. Because of the two different types of perches, and the angles where the suspension meets the perch, I can't see them being in the same relative position. Not 100% sure and someone on here might have an axle tube from each truck to truely verify.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 06-26-2009, 03:49 PM   #5
Tx Firefighter
Re: 12 bolt axle
Not to mention, the perches for coil spring rears are on the bottom of the housing and for leaf rears are on the top of the housing.
