Old 05-12-2021, 11:20 AM   #1
54blackhornet
54blackhornet's Avatar
Radiator Drain Valve ?
I need to drain the radiator to remove intake manifold. I tried to turn the little spigot on the bottom but it’s stuck pretty good. I hit it with BP Blaster and figured Id leave it alone overnight. Any other suggestions to get it free ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-12-2021, 11:27 AM   #2
michael bustamante
michael bustamante's Avatar
Re: Radiator Drain Valve ?
is it the original copper brass radiator or a new aluminum with a plastic spigot?
1967custom
michael bustamante is offline   Reply With Quote
Old 05-12-2021, 11:53 AM   #3
sick472
sick472's Avatar
I always get confused on which way to turn them...are you turning it the correct way?
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 05-12-2021, 11:58 AM   #4
treveiger
treveiger's Avatar
Can give it a few light taps with a hammer to hopefully free up the stuck drain. Sometimes works sometimes doesn't. The old pull the lower hose works too just messy.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 05-12-2021, 12:32 PM   #5
Carl Spangler
Carl Spangler's Avatar
I have found it easier to slowly disconnect the lower hose at the tank to drain a bit of fluid.
1971 SWB step side: Original NM Forestry and then NM Fire truck
Carl Spangler is offline   Reply With Quote
Old 05-12-2021, 12:36 PM   #6
54blackhornet
Thanks guys ! The radiator is the original brass/metal one. I have learned from past mistakes NOT to try to unstick stuff that’s not been moved in years. I tried tapping it with a small hammer but it didn’t budge. I think loosening the bottom hose sounds less dangerous...
71 C-20
07 Magnum RT AWD
Old 05-12-2021, 02:29 PM   #7
HotWheelsFan
HotWheelsFan's Avatar
For sure...
Careful with things like that.
Step one: Think a sec, if it does break, where would that put me?
Sometimes no worse off, sometimes it could leave you with a bigger problem.
The last work I did to my truck, last summer... Tried to drain radiator My drain plug broke right off. Cost me a new radiator.
HotWheelsFan is offline   Reply With Quote
Old 05-12-2021, 02:39 PM   #8
pjmoreland
pjmoreland's Avatar
The threads on my metal drain are backwards (left-handed). It threads into the radiator to open, so turning it counterclockwise opens it.
pjmoreland is offline   Reply With Quote
Old 05-12-2021, 02:40 PM   #9
sick472
sick472's Avatar
I have drained my 72 by siphoning it out through the radiator fill hole. I used a piece of 1/8" ID tubing (maybe 3/16") and a 5 gallon bucket. It was a bit slow, but not messy at all.
1972 C10
1985 K20
Old 05-12-2021, 03:22 PM   #10
RustyPile
RustyPile's Avatar
If it's a metal petcock and not a plug, you don't need to remove it from the radiator.. It's perfectly OK to use pliers to loosen it.. It opens by turning it counterclockwise..
RustyPile is online now   Reply With Quote
Old 05-12-2021, 05:07 PM   #11
54blackhornet
Thanks again fellas ! I used my head and let it sit overnight. Taped it again with no luck so I tried backing out the entire spigot from the tank. I got it to move so hit it again just now. Patience is something you learn over time. ...
71 C-20
07 Magnum RT AWD
Old 05-12-2021, 07:23 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
.... Often after breaking several things first....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
