02-17-2021, 05:15 PM | #1 |
Welding fumes from 2 car garage
Im welding in some floor pans in my 72 c10 using a mig setup with c25 in my attached 2 car garage. The living area of my house is on the next floor up and about 50 feet down from the garage. The garage has 8 foot ceilings and is seperated from the house by an exterior door. Im welding on 18ga mild steel with .030 wire at intervals of 10 minutes or less with breaks of 30 min to an hour in between for a couple hours a night. My question is, do you think the fumes from my welding are in high enough concentration to pose any risk to individuals on the next floor and 50 feet away? I know its impossible to say for sure or not but do you think it warrants clearing the house of occupants prior to welding or should I worry about it enough to invest in testing air samples? Or do you think the concentration (if any) would be so low that I shouldn't worry about it. Thanks in advance.
02-18-2021, 08:50 AM | #2 |
Re: Welding fumes from 2 car garage
Not a professional but a hobby weldor. Are you wearing any PPE for your lungs? How are you doing? You are a couple feet away, if you are doing ok, someone several walls and 50' away is going to be fine as well.
As long as you have cleaned the metal of all paint, primer, undercoat, zinc coating, etc., you should be fine. Clean steel to clean steel rarely causes problems. It is the paint and other things burning off that cause the problems. Keep the garage door open or at least part open with a well positioned fan to clear out the smoke to further mitigate any problem. I have had more issues with the dust created by prep grinding then actual welding. Don't use any automotive cleaning chemicals to prep your metals. Those exposed to heat CAN create deadly fumes. Brake cleaner is particularly nasty. |
02-18-2021, 08:53 AM | #3 |
Personally I don't think it's a problem. I've never had a problem and I have rooms above my garage.
I also never wear any kind of breathing apparatus when I weld anyways. I'm no professional but have been welding in my garage for twenty years. Kim |
02-18-2021, 12:45 PM | #4 |
Who Me?
Same as Kim, but I do try to avoid smoke from welding galvanized metals.
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-18-2021, 02:29 PM | #5 |
My question stems from wanting to keep my wife and kids safe. While I think they are perfectly fine being so far away, my wife thinks differently so I wanted to see others opinions. I normally open the garage door but with the temps hitting -20 this week and last, that just wasn't an option. I myself am perfectly fine and have no sensitivity to any of it and have been welding and grinding for years while using a respirator when grinding and staying out of the smoke stream when welding, welding on clean metal, staying away from galvanized etc. But now that I have kids, I figured I better look into it a little more. The good news is the weather is on the rebound so I can adequately vent to the atmosphere again but this is all great info for the future. I think im going to install some ducts in my garage hooked to an exhaust fan with a hepa filter and try to vent fumes through there. It'll double as a ventilator for when painting as well and hopefully keep me out of the dog house no matter what project I happen to be tackling
02-19-2021, 09:27 AM | #6 |
Who Me?
what about fans closer to the ceiling and blow towards the doors? Or if your garage has a side door, stick a fan in that door blowing out to keep air flowing thru the garage.
02-24-2021, 02:40 PM | #7 | |
Another room should be totally fine. Its not like you have a garage full of welders burning galvanized all day.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-07-2021, 07:46 PM | #8 | |
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
