Old 10-15-2021, 05:10 PM   #1
Bocephus69
Using van hydroboost - will van master cylinder work?
Is anyone using the master cylinder off their hydroboost donor vehicle? This came off a 2009 express 3500 van. If so... The van did not have a proportioning valve. Do still need to run one on the C10? Photo of van's master cylinder is attached
69 C10 fleetside long bed - 6.0/4l80E in progress
Bocephus69 is offline   Reply With Quote
Old 10-15-2021, 05:40 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Using van hydroboost - will van master cylinder work?
I would say yes.
The van is a full bodied vehicle and is going to gave a lot more weight over the rear wheels than a pickup does.
I would suggest an adjustable prop valve, so that you can tune what it really wants, rather than trying to match an off the shelf replacement.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-16-2021, 11:32 AM   #3
57taskforce
All about them K’s
57taskforce's Avatar
I’m using one off a 2009 silverado 2500HD in my 72 K20. I ditched the plastic master cylinder and used a new Napa master cylinder for a 72 K20 (my truck) on the Silverado HD Hydroboost unit which allowed me to use the OE proportion valve from my K20.
Hope that helps.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 02-09-2022, 12:47 PM   #4
Bocephus69
Hope that helps.
does the standard C10 master cylinder bolt right up to your 09 hydrobooster?
Old 02-09-2022, 04:59 PM   #5
Bigdav160
Bigdav160's Avatar
Mine did.
Discs front and rear? Or drums? The master cylinder will have a residual check valve for drums.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-09-2022, 05:34 PM   #6
Bocephus69
Originally Posted by Bigdav160 View Post
Mine did.
Disk/disk.
I ask because from my research the newer (07ish and up) GM hydroboosters havr a different bore where the master cyl attaches
