01-28-2023, 10:48 AM | #1 |
Parking brake pedal spring ?
My pedal will not snap back, is there supposed to be a spring in this assembly somewhere ? I'm aware of the small handle spring but don't see anywhere there could be another spring to bring the pedal back
01-28-2023, 12:02 PM | #2 |
Re: Parking brake pedal spring ?
Doesn't the spring on the cable going thru the frame bring the pedal back when properly adjusted ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-28-2023, 12:11 PM | #3 |
01-28-2023, 12:40 PM | #4 |
Here is a picture of one Dave sold.
Link: http://67-72chevytrucks.com/vboard/s...e+pedal+spring Here is a link of Leon selling the spring . Link: http://67-72chevytrucks.com/vboard/s...+spring&page=2
01-28-2023, 12:46 PM | #5 |
I studied this subject on my parking brake foot pedal and think there probably is a spring way up in there but I decided on mine it must be rusted and broken. I removed the assembly from my truck and cleaned it up and painted it, and added a general purpose spring that I bought in a pack of assorted springs from the hardware store. It works great. My add-on spring is attached between the cable attachment point (1), stretched under the assembly belly, to the bolt (2) that holds the conduit.
01-28-2023, 12:56 PM | #6 |
There are 2 other springs on the assembly, one is to make the release pull handle spring back in position, and one is for the clicker pawl. The release handle spring can be replaced with a small general purpose spring, and the clicker pawl spring best replacement in my opinion is a Irwin Tools vise-grip pliers spring which last I knew you can get for free from Irwin tools by mail, or buy online.
Neither one of these springs has anything to do with the pedal returning to position. The release pull handle spring is easiest to see and replace. For the clicker pawl spring I hooked the circular end of the vise-grip spring to the pawl inside the assembly near where the pawl sticks out through the little window. Then stretch it down and put the hook end of the spring on the belly of the assembly. Last edited by dmjlambert; 01-28-2023 at 01:13 PM. |
01-28-2023, 12:57 PM | #7 | |
The Older Generation
Thanks. The spring I have is only for the release handle. I think the pedal return spring is on the primary cable. LockDoc
01-28-2023, 01:15 PM | #8 |
I probably need to replace my primary cable and conduit assembly, then maybe the return of the pedal would have some more force and would not need my add-on spring. Maybe.
01-28-2023, 02:10 PM | #9 |
The springs that return the handle are located inside the back brakes. You know the ones that make it difficult to remove the shoes? Disconnect the two cables at the adjustment under the truck. You should be able to pull on the front cable while someone releases the brake from inside the truck. This will prove the front cable function. Just pulling on each rear cable with a vise grip will prove the rears. Just pull and the springs return the cable(s). I'd bet the issue is in the rear cables as they are close to the road and crap and only last so long. The real early trucks even had a zert fitting the the E-brake cables to avoid this exact issue. I now check them every time I complete a brake job. After I smoked a set of rear brakes of course.
Nice job on the E-brake actuator. Looks just like factory with the paint going only partly up the foot pedal. Cheers. |
01-28-2023, 02:52 PM | #10 | |
