09-09-2021, 03:16 PM | #1 |
Question about wood bed stain and sealer for my 1987
Finishing up with the restoration on my 1987 shortbed Stepside 4X4. I’ve ordered the new bed wood in pine and was wondering what color stain (if any) and what kind of UV resistant sealer to use? Trying to keep it original as possible without painting it black.
09-09-2021, 03:27 PM | #2 |
Re: Question about wood bed stain and sealer for my 1987
09-09-2021, 04:30 PM | #3 |
Beautiful truck!
Just curious -- were these wood floors originally painted black? What species of wood was used from the factory? I've seen a few wood-beds around, including a couple in a local salvage yard, but haven't known much about them. I'm surprised they made it the whole way to 1987, but I guess someone must have wanted them. Does your SPID sticker acknowledge the wood bed in any way?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-09-2021, 05:32 PM | #4 |
Robert Olson Transport
i used marine grade polyurethane on my bed
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
09-09-2021, 05:39 PM | #5 |
I have a step side too, and from my little knowledge of wood species. My conclusion it is some type of pine. As the few pieces I got from my factory bed floor appear to be that.
On my truck which needs a bed wood like fat kids love cake. I am looking at 2 major options. First one being Trex decking or similar as a install, and forget option. The second is to use appaton or similar wood which I pretty damn HD when it comes to stuff, but would still need periodic attention. My plan is to weld the bed togather so it is removable like new trucks with 4 bolts from underneath, and adding more center support for heavier items. So when finished the top is just smooth wood. My personal guess would be any stain in the color you want is going to be fine. After that you will need to roll or spray on UV rated polyurathane sealer. Sanding inperfecrions between coats, and building up a thick coating. How thick I don't know as I am not into finished wood items as a hobby. Though I probably would go to a premium paint store where real finish carpenters go, and not be afraid to drop some cash. |
09-09-2021, 06:30 PM | #6 |
I cannot personally attest to this product. But, I do know they have done serious extensive testing on various stains, etc on the wood they sell. Results are also on their webste.
https://www.mar-k.com/webPage.aspx?ID=14 |
09-09-2021, 09:07 PM | #7 | |
Wood species was pine. The SPID does not acknowledge the wood floor in any way because all of the stepside beds had wood floors. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-09-2021, 09:51 PM | #8 |
Thank you Keith, that was my thoughts on the bed info. I went to great lengths (having the original 114,000 mile engine rebuilt) to keep the truck as close to 100% original as I could ….except I’m not gonna paint the bed wood
09-09-2021, 09:52 PM | #9 |
Also, thank you everyone else for the info!
09-09-2021, 10:14 PM | #10 |
What about the wood floor fleetsides? Were those denoted any differently? The one I saw in a salvage yard was a fleetside with a wood floor.
09-09-2021, 10:18 PM | #11 |
Truck looks great..!
09-10-2021, 08:40 AM | #12 |
Wow, what a gorgeous restoration.
I have never seen an original factory black stepside in person, Wonder if the "body color" rule applied to them or if black was the exception.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
09-10-2021, 09:03 AM | #13 |
The Mar-K tests reports are a GREAT read. I ended up using the POR-15 on the underside and just used an oil-based stain (penofin brand) on the upper side (my 72 C10). I did not what the clear coat as it tends to yellow and or chip and peal after time. My truck gets a few thousand miles a year and sits in some weather while I'm at work which would encourage a clear coat to break down. With that said, you can't beat a well done clear coated show truck bed. The oil stain option that I went with will require a yearly (or every two years depending) wipe down with some oil to keep it fresh looking, but that is only an hour or two job.
Here's a thread from the 67-72 forum that discusses bed oil treatments that you might find interesting... https://67-72chevytrucks.com/vboard/...d.php?t=712931
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
09-10-2021, 09:21 AM | #14 |
Any Stain alone will not last long as they are meant to have a poly protection. The more pigment in the stain the greater the UV protection. Marine Spar is the best, but there is no clear oil. Linseed has a yellow tint and will darken. You can factor in the yellow with your stain choice(going Lighter) and get what you want. The acrylics are quickly catching up to the oils so there are some decent ones. This is my experience from having refinished a few hundred Front doors in my career
09-10-2021, 11:12 AM | #15 |
Thanks, truck was zero rust, all original body panels. We used a polyurethane single stage paint, very similar to Imron.
Prior to resto…. |
09-10-2021, 07:01 PM | #16 | |
We haven't talked much about how the RPOs work, but they stack to create shorthand "sentences" that describe the particular truck. So - NAPCO's would be: K10703 & E62. Which, in English, would be a 4WD 10 series short wheel base pickup with a stepside box (no mention of wood floor, because they are all wood floor). If it was a long wheel base it would be captured in the model type, ie: K10903 & E62. If his truck was a fleetside, it would be: K10703 & E63. for a metal floor. Wood floor would be: K10703 & E63 & E81. Stacking the RPOs like this helps you get very quickly to the specific part needed, especially with things with a lot of proliferation like radios, axles, radiators, engines, etc. A separate part number is pulled and new part created to cover each available permutation. K
09-10-2021, 08:41 PM | #17 |
Excellent Keith
09-12-2021, 08:58 PM | #18 |
Sb 400 club
I also need to redo the wood in my 77. Its so bad the front of the bed dropped down and makes it look like my truck has a bad frame. I was looking at pine but would rather have oakor something tough: i only want to do this once. My truck is outside with big weather swings.
Whose wood kit did you end up going with? When i used to build wooden skiffs the best spar varnish finishes got sanded between coats and multiple coats.. i am talking over 10…….
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
09-12-2021, 11:04 PM | #19 |
If its not a show truck you can get used hydraulic oil for free at your local AG or construction equipment repair facility.
It is 10wt oil and comes out as clean as it went in. Make a trough out of large pvc pipe or something and soak the planks. Here in the High Desert it will attract dust and be nasty for a while. Then its fine. I noticed how on the flat bed trailers the oil soaked areas looked 1 or 2 years old while the rest of the wood was dry, flaky, and splitting.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
09-13-2021, 07:36 AM | #20 | |
Bed Wood and Parts, LLC
8345 Madisonville Rd Hopkinsville, KY 42240 Phone: 270.424.3000 Quote:
09-15-2021, 08:37 AM | #21 |
From my research, the best wood to go with is white oak as far as commonly found lumber in the US. I ended up going with red oak for the added color, but the white oak will withstand rot just a bit better.
