10-10-2021, 08:32 PM | #626 |
Re: My 1970 GMC “Project Splice”
More progress today on the truck. The pictures really don't look a whole lot different but I have completed a ton of sanding today as well as a second coat where ever nessaccary. Most of my second coat is sanded as well so I will be below the trim pins next chance I have to get out there. My finger tips are almost bleeding and most of my fingerprints are gone. Now would be there perfect time to rob a bank to fund the rest of my build.
10-13-2021, 12:39 AM | #627 |
Well a whole evening of bondo work and I have hardly anything to show for it. Those trim pins are a b*****d to sand around.
10-13-2021, 08:47 AM | #628 |
Just saying.... Looking good though man. Getting closer now. |
10-13-2021, 09:15 AM | #629 |
Haha funny you post that. I was just looking at one of those at home depot yesterday. Not in the budget right now unfortunately. And thanks.
10-13-2021, 02:05 PM | #630 | |
My brother in law has that one and all the other Milwaukee battery tools at the shop so I get to use them when I'm there. LOL |
10-13-2021, 02:10 PM | #631 | |
10-13-2021, 02:20 PM | #632 |
Yea mine is especially bad when I weld sheetmetal. I put some tacks on and then use the blow gun to cool the metal and rinse and repeat. It runs constantly until I stop welding.
10-14-2021, 11:26 AM | #633 |
I have bought one of these and love it! Looking at buying another just so i dont have to switch from tools as often. Worth the investment!
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
10-14-2021, 11:27 AM | #634 |
Good to hear. It will be on my list of things to get.
10-18-2021, 12:23 PM | #635 |
I am going to be doing rollcages on both my sons C10 and my LS swapped S10 so I am going to buy one of these.
Just ordered one of these hole saw bits to drill 1 5/8' holes for mounting a crossmember through the frame. Last edited by sakustoms; 10-18-2021 at 12:33 PM. |
10-18-2021, 02:49 PM | #636 |
That's a pretty nifty looking tool for getting nice notches in pipes. Should save you a ton of time on trial and error.
10-18-2021, 08:30 PM | #637 |
Well folks, I'd highly recommend running a straight edge along a long panel before you start doing filler or you end up like me, removing a section that was "finished" but was not straight. I noticed today while finishing up sanding around those darned pins that the passenger side had a nice bow to it. I had to remove a section of filler and run the pinner down the length of the body line under the pins on the passenger side 3 times to get the bow out. Then I had to remove a bit more filler because the heat from the pinner melted off sections of filler. Man am I good at this.
The picture doesn't show how bowed it actually was. I hadn't dug out the filler yet that was already 1/8" thick. The worst of the bow had to be about 3/16" or greater. |
10-19-2021, 05:17 PM | #638 |
Man you've come a long way on this thing! I bet you gotta be excited getting close to laying some primer and color!
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
10-19-2021, 05:19 PM | #639 |
I sure am although colour is going to be a while yet. I wanted to get the cab in primer so that I can get going on the frame and not have to worry about rust.
10-19-2021, 07:42 PM | #640 |
Finally finished sanding around the dreaded pins. Now that I have that completed, it's almost smooth sailing from here. Though I will need more filler soon.
10-20-2021, 06:33 PM | #641 |
Just about finished up the driver side pillar today. Coming out very nicely!
10-24-2021, 08:24 PM | #642 |
Got some more filler layed down and sanded off today. I've been struggling with a wave that I can't seem to get rid of where I welded up the original gas filler. I think my next attempt will be successful as I have hammered down a few high spots. While working with that, I also started to fill the vertical sections between all the dimples in the back of the cab. Slowly but surely getting there. Picked up a new gallon of filler the other day as well so I'm prepared.
10-24-2021, 08:33 PM | #643 |
Nice work. I know, it sucks to do bodywork, but it will payoff in the end.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
10-24-2021, 08:39 PM | #644 |
Thank you. I honestly don't mind the actual bodywork itself, it's the dang dust everywhere that really sucks. If a guy goes into it knowing that it is a tedious job it's not so horrible. It will for sure payoff in the end and I'm excited to see the cab in primer.
10-24-2021, 09:34 PM | #645 |
I am still watching
10-24-2021, 09:37 PM | #646 | |
10-25-2021, 11:25 AM | #647 |
I do not envy you one bit. LOL
Then again I will be doing a bunch of bodywork so I know exactly how you feel. Just mocked up the mounts for the twin turbos yesterday so bodywork is now at least one step closer. |
10-25-2021, 04:22 PM | #648 |
That's awesome! I am jealous that you appear to be completely ready for body work on all the panels. I still have alot of metalwork in my future.
10-26-2021, 08:24 AM | #649 | |
It's a never ending story. |
10-26-2021, 10:08 AM | #650 |
