Old 02-19-2008, 03:11 PM   #26
extd56
extd56's Avatar
Re: Project Big Brother!
Here are some fenders still atached to a bed for sale, probably cheap.
http://chico.craigslist.org/pts/575995872.html
extd56 is offline   Reply With Quote
Old 02-19-2008, 04:15 PM   #27
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
I think this will end up being your Best Creation to date, Really looking forward to the Start of the Build. Do u have a Projected Time for the Start?
Thanks for making my & I'm sure several other's Dream Truck...............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 02-19-2008, 08:29 PM   #28
Hart_Rod
Hart_Rod's Avatar
The truck was on the cover (I think the Burb was too.) I've got it in ABQ, I'll post the issue when I get back there tomorrow, if you haven't figured it out by then.
Hart_Rod is offline   Reply With Quote
Old 02-19-2008, 10:09 PM   #29
Rokcrln
Rokcrln's Avatar
I like it better when they are sitting in your back yard!
Rick
Project start time will be after Trazer is finished and when I have down time between other projects. The first part of the build (burb w/4th door) will not take to long. getting to the rest will take a bit longer.
Thanks I will head ouit into the cold and take a look
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 02-20-2008, 02:47 AM   #30
Frizzle Fry
Frizzle Fry's Avatar
I like the rear fenders in the first pic, not the second. And of coarse yours will have a 4th door and a better roofline.
Frizzle Fry is offline   Reply With Quote
Old 02-20-2008, 03:19 AM   #31
Rokcrln
Rokcrln's Avatar
I agree! But unlike the first pic it will be a short bed and the fenders will get narrowed (3-4") to just fit the tires. Yes the roof will flow better and the rear doors will have the truck upper section. I think it will make for a sweet tow rig for longer family trips. Also Nate thinks we can find a HD rack and pinion for the DropMember that will hoild up to the weight of a diesel
Thanks for the pic's!
Kevin
LFD Inc.
Old 02-20-2008, 04:06 AM   #32
hotrodhomi
hotrodhomi's Avatar
how much more does the diesel weight? including turbos of course
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-20-2008, 04:26 AM   #33
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
What Front Clip Are You Going To Use?
NTR72GMC is offline   Reply With Quote
Old 02-20-2008, 08:34 AM   #34
Rokcrln
Rokcrln's Avatar
Not sure on ether one of these questions.
Here are a few pics from delivery.
Kevin
LFD Inc.
Old 02-20-2008, 09:42 AM   #35
extd56
extd56's Avatar
And not even a tip or any goodies to eat.
Old 02-20-2008, 10:14 AM   #36
jugernot
Life, Be In It.....
jugernot's Avatar
I found an old pair of steps for the step fenders. You can have them if you want them. They may be good for another project down the road. They were the ones we had on lemon drop's bed when you were doing the body work. They have been blasted and are in primer.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 02-20-2008, 10:41 AM   #37
cflvulcan
cflvulcan's Avatar
im real excited to see this build. this sounds like the dream truck ive been building in my head for so long. ive watched every build you've done and im very impressed by your work. im only 20 and ive grown up around rebuilding old cars/trucks with my dad and i really look up to you and your work cause i know what it takes. and someday id like to be on your skill level. good luck on this project, i cant wait to the progress...
cflvulcan is offline   Reply With Quote
Old 02-20-2008, 11:05 AM   #38
Rokcrln
Rokcrln's Avatar
Sounds like my price range Thanks.
Thank you that was very kind of you. I enjoy building stuff that the factory din not. Trust me if you keep it up you will pass me in no time. I am jealous of you and your Dad, mine plays golf!
Kevin
LFD Inc.
Old 02-20-2008, 12:26 PM   #39
5150.4.67
The cummins 5.9 has about 1100 pounds of heft. The others I believe are slightly less. So ballpark figure around 250+ lbs more.
5150.4.67 is offline   Reply With Quote
Old 02-20-2008, 12:49 PM   #40
gringoloco
A guy with a truck
gringoloco's Avatar
Another one of my ideas down the tubes. At least I know you'll do it justice.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-20-2008, 08:53 PM   #41
hotrodhomi
hotrodhomi's Avatar
So with only 250 lbs more, why the need for beefer rack and pinion?
'66 impala ht
Old 02-20-2008, 09:07 PM   #42
Rokcrln
Rokcrln's Avatar
I think that is #250 over a BBC!
I belive it is due to the total weight of the finished vehical and the direct weight on the steering axel it self. The standard rack used is over rated for the standard truck set up but comes right to the edge of what I am looking at doing. I also have plans for towing an enclosed 28' trailer that I figured into the use of this vehical when I went to Nate for advice. So if this was just going to be a lowered street vehical with out trailer use it would be fine but very close. I am sure Nate can explain it better but one thing I know is if he is not comfortable with it he will not sell it to you. This is why he wanted to know about the end use as well as the full vehical build before he gave me advice. At first I only asked if a drop member would work for a dually then he came back wanting to know more.
Kevin
LFD Inc.
Old 02-21-2008, 01:30 AM   #43
67ChevyRedneck
67ChevyRedneck's Avatar
Man o man, kevin! What happened to thinning the herd?
Looks like a great start to your project.
The 4th door sounds awesome. Frizzle has the "tahoe" and you've already made a 4th door crew cab out of a burb (even if you didn't "start" the conversion) so why rehash what's already been done
You like to be an innovater... so how's this sound...
68 front clip.
Your turn signal mod.
4th door mod.
Here's the kicker....
1967/68 AVALANCHE.
It might be cooler in my head than in real life... get a burb gate that goes down (the one like a tailgate) and cut the body off below the window line, close off the back of the "cab" with a truck cab, finish off the top of the "bedsides" with top rails from a 67-72 bed, or better yet graft a whole 67-72 bed end onto the burb, tailgate and all...
Sigh, I wish I had skills to do this and not live through others
*Just thinkin' out lout 'cause I know you have the skills to do it. You're plans for it are really awesome
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-21-2008, 07:50 AM   #44
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Your new project sounds killer. Nice to see you not take any time off between projects and have more to work on that can keep you busy.
I am liking the idea of a Suburban turned into a 4 door like an Avalanche which is what I kind of translated this build into at first.
I may be reading into this wrong but are you doing a 4 door truck,with a separate bed with dually fenders OR a 4 door Suburban (avalanche style) with dually fenders??
I will be watching for new build threads.
Oh and thanks to all of you for the motivation to get working on my project again finally.........dont know where my head has been lately but I will really appreciate the sound of a thumping small block counting off at an intersection again here before too long..
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-21-2008, 08:50 AM   #45
Rokcrln
Rokcrln's Avatar
68 front clip.
4th door mod.
1967/68 AVALANCHE.
Thanks for the thoughts but it has been done before and does not look very goon in my book. I like custom rigs that have a more factory look. Like Low Buck it looks like a clean stocker that has been lowered untill you start looking deeper. I am going for the same kind of build with this. I will save the all out trick stuff for my 2wd Blazer build.
It will have a seperate SWB bed or shorter with step side fenders cut way down for tire coverage. The cab will be a 4dr with burb front doors for the square top corner and hybrid rear doors using teh truck top corner and the back of a truck cab reworked abit.
Kevin
LFD Inc.
Old 02-21-2008, 09:04 AM   #46
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Gotcha,I think redneck and I were thinking along the same lines.
I remember a deep maroon late 90's Tahoe that was done up like an Avalanche in a mag once.
Old 02-21-2008, 10:41 AM   #47
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Rokcrln View Post
Does anyone remember what issue this truck was in? I know he had a bad looking burb as well in I think the same mag. I have it in my shop but with out knowing what issue it was in I would spend hours looking for it. Was it the cover truck or was the burb? Thanks
Kevin
LFD Inc.
December 2004 (Wow, was it really that long ago!), Volume 13, NO. 12.
R/
Old 02-21-2008, 09:53 PM   #48
67ChevyRedneck
Kevin
LFD Inc.
It's gonna look awesome (and yeah, low buck looks killer!)
Sounds like you're going to do a "small" fender addition like the older sierra denalis? I always thought that was a cool touch GM added to those trucks.
R/
WOW! It was THAT long ago? That's one of the best looking trucks I've ever seen. I wanted a "crew cab" after seeing that truck!
Jesse James
Project "On a Dime"
Old 02-22-2008, 01:54 AM   #49
Frizzle Fry
It will have a seperate SWB bed or shorter...
I'm diggin that. I like the look of super short beds as long as they are seperate and on this thing with the long cab and mini-dually fenders it would look awesome. We need a rendering!
Edit:
Always liked this super-shorty; just add a crewcab and your mini-fenders...
Old 02-22-2008, 07:37 AM   #50
Rokcrln
Rokcrln's Avatar
Edit:
That one does look good. I will have to do some renderings to see just how a real short bed looks with a crew cab. I think if I went that short it may make the front look too heavy. I will play around with 6 1/2' and 6' beds and see what works the best. I might also play with rear axel placement. I think a few inches forward or back of a stock SWB could make a big differance as well.
I havw been checking around and I might just find a rolling 73-88 crew cab dually frame for this build as it would be much beefier than the 1/2T burb frame. I really want the diesel power so I want to make sure everything else is up for the task.
Kevin
LFD Inc.
