02-07-2008, 08:24 PM | #76 |
Re: Project: Bolt one on
Trial fit of the drivers side inner rocker happened this morning.
Used a new piece that's now available, made for trucks but being it has the four 'A' pillar holes and partial floor at the seam it's a good part to use on blazers to IMO. After 'trial' fitting a couple/few times (notice scratches) it fit up pretty well. |
02-07-2008, 08:32 PM | #77 |
Can't wait to retire!!
Cool! I was just thinking about this project yesterday, but I couldn't remember the thread name and was too lazy to look it up.
Good progress. Where might those have come from? Tri-Pro Automotive perhaps? I'm going to need those as well.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 Last edited by Chevyman63; 02-07-2008 at 08:32 PM. |
02-07-2008, 10:30 PM | #78 |
Nice work, great fit Vt. Nice idea on the inner pc. Do you have to do the floors as well. Tim, I think he got all his parts at Tri-Pro. If you look at the 'A' post patch laying there, I believe it's their insignia, but I could be wrong
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-07-2008 at 10:35 PM. |
02-07-2008, 10:40 PM | #79 | |
Have both sides here already but plan on only using what is needed on each side. Hope to save as much of the original floor as possible. Correct, the parts came from Tri-Pro. |
02-09-2008, 08:26 AM | #80 |
Trial fit with the doors turned into a need to bolt down body mount positions #1 & #2 to see where things really were.
Had to shim the firewall mount some but nothing major. Decent fit for the first go 'round, now I know we're in the ball park and now can fit up the inner rocker and lower 'A' pillar where they will stay. |
02-09-2008, 08:31 AM | #81 |
Things are rolling along. Nice!
Are you painting this one as well...and reassembling it too?
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 Last edited by Chevyman63; 02-09-2008 at 08:34 AM. |
02-09-2008, 09:37 AM | #82 |
Nice gaps, that is where the work really shows. No wonder mine took so long, my hammer is no where near as big as yours
02-09-2008, 10:11 PM | #83 |
02-10-2008, 01:13 AM | #84 |
Grendel, what color will it be? I sure hope I haven't asked that before
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-10-2008, 11:15 AM | #85 |
Stock goldish color.
02-10-2008, 08:51 PM | #86 |
Welded the nuts on the inside of the cab mount and test fit the 'a' pillar for final fit, installed the inner rocker for final, then test fit the outter.
02-10-2008, 09:38 PM | #87 |
Well you've done it again. These pics are just what I needed to be inspired enough to actually accomplish something on mine today.
Thanks again and nice work as usual!
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
02-25-2008, 06:21 PM | #88 |
Lower pillar and inner rocker almost done.
Next is to reinstall the door and fit up the outter rocker. |
02-28-2008, 04:15 AM | #89 |
Outer rocker installed.
The gap between the door and the 'b' pillar would of course be closer in final install but it was straight on the first try so I didn't mess with it. |
02-28-2008, 04:28 AM | #90 |
Nice fit! Couldn't ask for any better
02-28-2008, 04:33 AM | #91 |
You're getting pretty good at this body work stuff...I may have you stick around here for about a week or two to finish mine.
Nice work!
02-28-2008, 08:40 AM | #93 |
1971 4X4
nice work!! Keep the pictures coming.
MN ROOKY 1971 Chevy 3/4 4X4, 4" lift, 33's 2001 Chevy 3/4 4X4 HD, 33's (Wife's Truck) |
02-28-2008, 07:21 PM | #94 |
That does look like a great fit. It's coming right along.
02-29-2008, 03:13 AM | #95 |
Looks good Kurt!
Seeing your progress pics makes the TriPro backorder even MORE painful... I'm jones'ing to get into the shop to burn some metal on my own K5.
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
03-02-2008, 08:29 AM | #96 |
i see the body work continues!! Looking good. Never had the patience for that kind of work. Kudos to those of you that can.
03-02-2008, 11:53 PM | #97 |
"1972 C5"
Very nice work...
03-03-2008, 08:16 AM | #98 |
03-17-2008, 08:15 PM | #99 |
I am starting to look forward to getting this back and finishing up.
Ordered 120' of DOM tube, which is now sitting under Shuffling. |
03-27-2008, 02:55 PM | #100 |
Tuesday 3/25/08:
Cut and patched drivers side floor. Cut-cut-cut...out passengers side floor. |
