Old 05-29-2021, 02:51 PM   #1
Meangreen1
Active Member
TR6060 to Np205 question
I am looking to use a tr6060 in my 69 K20. Has anyone done this swap or know what is needed? I am going the LS route as I just spun a bearing yesterday on the 350. I have done 3 ls swaps now and that’s the simple part for me. Never done a 4WD truck and need advice. Thanks you!
Meangreen1 is offline   Reply With Quote
Old 05-29-2021, 03:25 PM   #2
Louisvillekytruck
Re: TR6060 to Np205 question
Nice truck any lift and what size wheels and tires
Louisvillekytruck is online now   Reply With Quote
Old 05-29-2021, 11:05 PM   #3
Meangreen1
Active Member
4” lift with almost 35” tires, 17” rim
Old 05-30-2021, 12:48 AM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
The TR-6060 being mainly used in cars like the Camaro and Corvette is going to be the biggest limiting factor in your swap. Only a couple of companies show a 4wd/awd version. Rockland Standard Gear is one that offers the true 4wd version. The other shop is selling a version that mates up to a AWD t-case.
TR-6060's aren't cheap to start with. Add in the modifications required to make it compatible with a T-case and the price keeps going up.
Given that the truck looks like a nice restored driver I'm guessing you are just wanting more fun/control of the driving with the future LS swap. They don't list the gear ratios but if they are the same as the car version it's going to be lacking unless you stick with low gears in the axles with the 35's. I'd be looking at 4.56's at least. It would still allow off the line acceleration and be able to use the double overdrive gears.
However, given the cost and the lack of choices going with the 6060, I'd look at a NV4500. It's a pretty well known swap that works. Yes, the 4500 has a granny gear which can prove to be pretty handy when towing or snatching a boat out of the water on a steep ramp. They are pretty good off road too if you are so inclined. GM sold them behind Big Blocks (GMT400) and the 6.0L LS engine in the 3/4 ton GMT800 trucks.
If you are keeping the LS close to stock and not going crazy off road, the NV3550 trans was used in the 1/2 ton GMT800 trucks. It's a 5-speed too, but no granny gear.
I'm going on 6 months so far with the NV4500 in my K5 and an 8.1L big block. Got to say I love the combination. Tons of grunt down low and the 5 speed lets me pick the right gear when I want it, not when the computer says so. I will say the torque has spoiled me and limited the need for shifting some. If I'm not trying to show somebody my tail lights I tend to skip gears as I accelerate up to speed. 2nd-3rd-5th or 2nd-4th-5th.
A second OD gear would be useless in my case other than dropping the cruise rpm a slight amount. But that slight amount would not net a major fuel mileage increase to justify the cost of a converted 6060 trans. That's at least in my case though.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 05-30-2021, 06:39 AM   #5
Bigdav160
Bigdav160's Avatar
I guess Zoomad covered it but I was thinking - that transmission never came in a 4x4 application, did it? going divorced transfer case? Boy that's a lot of work.
And the gear ratios have to be wrong, right? I mean the tremec is a sports car transmission (have one in a Cobra/Coyote project), It seems like the wrong application.
If you really want a 6 speed, Dodge had a couple -NV5600 and the G56 that might be better and easier to deal with.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-30-2021, 11:59 AM   #6
Meangreen1
Active Member
Thank you for the information. The tr6060 was an option due to I can get one for a decent price and I am familiar with. I used one in my 72 2wd Blazer. Heard of guys using them in 4WD on a daily driver. That all said, I do like the granny 1st of the Nv4500. Seems all I can find is a dodge one. Is the gm bell housing easy to come by to bolt up with an LS? On a side note that 8.1 sounds like a fun build.
Old 05-30-2021, 12:00 PM   #7
Meangreen1
Active Member
Would love a 5600. I had a 04 Cummins with one. Hard to find reasonably priced.
Old 05-30-2021, 01:49 PM   #8
Zoomad75
K5Camper
Zoomad75's Avatar
The Dodge version won't bolt up to a GM bellhousing.
There are two GM bellhousing styles that were used. '95 and down used an external slave that was mounted to the passenger side of the bell. That can be problematic with your truck since it is on the same side as your front driveshaft. They have been used, but you need to watch the clearance. The '96 and up bellhousing uses an internal slave that makes it much easier to adapt.
There is a third option using an aftermarket bell from Advanced Adapters. It can use the stock mechanical linkage for the throwout bearing or use the late Squarebody external slave on the driver side. They are proud of it for sure.
The LS engine uses the same bellhousing mounting surface as any conventional small or big block, but does not use a bolt in the 2 o'clock position as you look from the back of the engine.
With either GM bellhousing you'll need to make the switch to a hydraulic system. I don't have experience converting a 67-72 truck to hydraulic though, but I'm pretty sure others around here have.
Rob Z.
Old 05-30-2021, 02:11 PM   #9
mongocanfly
mongocanfly's Avatar
there are factory parts to bolt a nv4500 to a LS...i couldnt find all the stuff to do it when i did either of mine...i had to use the kit from advance adapters...which works great...not cheap...
im currently looking at a tremec tr4050 setup for the next LS build...also not cheap...
i have a tr6060 in my shop...looking at it i dont think a transfer case could bolt to it at all..could be wrong...
you could do a divorced transfer case behind it though but with the crazy yoke it has youd need a u-joint adapter
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-31-2021, 12:30 AM   #10
Overdriven
Fasterproms YouTube channel did a t56 to 4wd transfer case in an S10 using an adapter from LOJ who does a lot of LS conversions in Nissans. I don’t think this is a regular production item for them or listed on their website so custom order kind of thing. Tr6060 is similar to t56, tailhousings interchange which in this instance is removed for the transfer case adapter. Apparantly the cyclone/typhoon guys have done this swap before too. But as stated in other posts this isn’t a “truck” style trans and will change the gearing a lot, depends on what you’re going for.
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla”
1967 Camaro 327 ‘glide cruiser “Bailey”
Overdriven is offline   Reply With Quote
Old 05-31-2021, 09:07 AM   #11
b454rat
96 n up GM bell will bolt up to a Dodge NV4500. Swap input and t-case.
Old 06-26-2021, 06:21 PM   #12
Jeff's bowtie's
Modern driveline offers a nice hydraulic clutch setup and simple to install
Jeff's bowtie's is offline   Reply With Quote
Old 06-29-2021, 01:01 PM   #13
mattshea125
mattshea125's Avatar
If you don't need to have a stick, have you thought about going to a 4L80E swap? I just did one in my 78 K20 behind a 454 and it made a huge difference in drivability and mileage.
mattshea125 is offline   Reply With Quote
